Need Help!!
Old Aug 16, 2010 | 08:14 AM
krackerstache's Avatar
Need Help!!
OK so i basically have a air filter and a custom 3" CBE with a AEM Tru-Boost Controller and Wideband Installed...
I noticed i'm running rich while cruising and lean under WOT is there anyone out there with a base map that i can help me??
I Run 93 oct daily and after i change the oil i do a mix of half 93 half CAM 2 110 oct race gas
I have an OBD II port with ECU Flash and EVOScan 2.7 installed on my net book
Old Aug 16, 2010 | 08:42 AM
derekste's Avatar
how lean are we talking?
Even though you just have a filter, you may need to maf scale. why are you mixing gas? is the 110 leaded?!?
Old Aug 16, 2010 | 09:05 AM
Um off the top of my head i think its like 12.3 and yeah the 110 is unleaded and i do it to clean the injectors... i heard that the mix is good for that... i would to a full take of 110 but its 9.78 a gallon so i do half and half cuz i can't be droping that kind of guap about twice sometimes 3 times a month
