XML for Lancer X
now this rom http://zalil.ru/29743569
Last edited by ayashiko; Sep 29, 2010 at 02:48 AM. Reason: http://zalil.ru/29743569
This is all I got:
Code:
<rom> <romid> <xmlid>52320006</xmlid> <internalidaddress>5002a</internalidaddress> <internalidhex>52320006</internalidhex> <make>Mitsubishi</make> <market>USDM</market> <model>Lancer</model> <submodel>SBT X</submodel> <transmission>4EAT</transmission> <year>2008</year> <flashmethod>mitsucan</flashmethod> <memmodel>M32186F8</memmodel> <checksummodule>mitsucan</checksummodule> </romid> <include>evo10base</include> <table name="High Octane Timing Map" address="5364f"> <table name="Load" address="5b574" elements="13"/> <table name="RPM" address="5b546" elements="20"/> </table> <table name="Low Octane Timing Map" address="5375b"> <table name="Load" address="5b574" elements="13"/> <table name="Y" address="5b546" elements="20"/> </table> <table name="MIVEC Intake #1" address="59b37"> <table name="Load" address="5bac2" elements="10"/> <table name="RPM" address="5badc" elements="22"/> </table> <table name="MIVEC Intake #2" address="59c1b"> <table name="Load" address="5bac2" elements="10"/> <table name="RPM" address="5badc" elements="22"/> </table> <table name="MIVEC Exhaust #1" address="59cff"> <table name="Load" address="5bac2" elements="10"/> <table name="RPM" address="5badc" elements="22"/> </table> <table name="MIVEC Exhaust #2" address="59de3"> <table name="Load" address="5bac2" elements="10"/> <table name="RPM" address="5badc" elements="22"/> </table> <table name="Ignition Warmup Retard" address="56cef"> <table name="Load" address="5b574" elements="13"/> <table name="RPM" address="5b546" elements="20"/> </table> <table name="EGR Timing Advance" address="54860"> <table name="Load" address="5ba76"/> <table name="RPM" address="5ba5c"/> </table> <table name="High Octane Fuel Map" address="53027"> <table name="Load" address="5b510" elements="13"/> <table name="RPM" address="5b4ee" elements="14"/> </table> <table name="Low Octane Fuel Map" address="531a3"> <table name="Load" address="5b510" elements="13"/> <table name="RPM" address="5b4ee" elements="14"/> </table> <table name="Fuel Alt #1" address="530e5" level="3"> <table name="Load" address="5b510" elements="13"/> <table name="RPM" address="5b4ee" elements="14"/> </table> <table name="Fuel Alt #2" address="53261"> <table name="Load" address="5b510" elements="13"/> <table name="Y" address="5b4ee" elements="14"/> </table> <table name="Fuel Injector Scaling" address="51898"/> <table name="Injector Battery Voltage Latency Compensation" address="5344a"> <table name="Battery Voltage" address="5b482"/> </table> <table name="Injector Base Latency" address="51200"/> <table name="Evap Map #1" address="53867"> <table name="Load" address="5b574" elements="13"/> <table name="RPM" address="5b546" elements="20"/> </table> <table name="Evap Map #2" address="53973" level="3"> <table name="Load" address="5b574" elements="13"/> <table name="RPM" address="5b546" elements="20"/> </table> <table name="Open Loop Load Low Octane #1" address="5334c"> <table name="RPM" address="5b3c6" elements="16"/> </table> <table name="Open Loop Load High Octane #1" address="54908"> <table name="RPM" address="5b3c6" elements="16"/> </table> <table name="Open Loop Load Low Octane #2" address="53360"> <table name="RPM" address="5b3c6" elements="16"/> </table> <table name="Open Loop Load High Octane #2" address="5491c"> <table name="RPM" address="5b3c6" elements="16"/> </table> <table name="Cylinder Fuel Trim #1" address="54eb1"> <table name="Load" address="5b510" elements="13"/> <table name="RPM" address="5be42" elements="14"/> </table> <table name="Cylinder Fuel Trim #2" address="54f6f"> <table name="Load" address="5b510" elements="13"/> <table name="RPM" address="5be42" elements="14"/> </table> <table name="Cylinder Fuel Trim #3" address="5502d"> <table name="Load" address="5b510" elements="13"/> <table name="RPM" address="5be42" elements="14"/> </table> <table name="Cylinder Fuel Trim #4" address="550eb"> <table name="Load" address="5b510" elements="13"/> <table name="RPM" address="5be42" elements="14"/> </table> <table name="Throttle Map #1"> <table name="Unkown" elements="44"/> <table name="RPM" elements="10"/> </table> <table name="Rev Limiter" address="5125e"> </table> <table name="Stationary Rev Limiter" address="5162e"> </table> <table name="Speed Limiter" address="51262"> </table> <table name="Airflow Check #1" address="5a4c7"> <table name="TPS-Related" address="5c8c0"/> <table name="RPM" address="5c89c" elements="15"/> </table> <table name="Airflow Check #2" address="5a5a1"> <table name="TPS-Related" address="5c8c0"/> <table name="RPM" address="5c89c" elements="15"/> </table> <table name="Airflow Check #3" address="5dd1b"> <table name="TPS-Related" address="5e010"/> <table name="RPM" address="5ce54" elements="15"/> </table> <table name="Torque Limiter #1" address="5dc75"> <table name="TPS-Related" address="5c8c0"/> <table name="RPM" address="5c89c" elements="15"/> </table> <table name="Torque Limiter #2" address="5dd6b"> <table name="TPS-Related" address="5c8c0"/> <table name="RPM" address="5c89c" elements="15"/> </table> <table name="Torque Limiter #3" address="5e65f"> <table name="TPS-Related" address="5e010"/> <table name="RPM" address="5ce54" elements="15"/> </table> <table name="Knock Filter #1"> <table name="Load" address="0"/> <table name="RPM" address="0"/> </table> <table name="Knock Filter #2" address="5692b"> </table> <table name="Knock Filter #3" address="56873"> </table> <table name="Knock Filter #4" address="567bb"> </table> <table name="Knock Filter #5" address="5664b"> </table> <table name="ECU ID" address="5002a" type="1D" scaling="ECU ID"/> <table name="ECU Options Set #2"> <table name="Periphery Bit Number"> <data>bit.15</data> <data>bit.14</data> <data>bit.13</data> <data>bit.12</data> <data>bit.11</data> <data>bit.10</data> <data>bit.9</data> <data>bit.8</data> <data>bit.7</data> <data>bit.6</data> <data>bit.5</data> <data>bit.4</data> <data>bit.3</data> <data>bit.2</data> <data>bit.1: Rear O2 ON/OFF</data> <data>bit.0</data> </table> </table> <table name="MUT Table" address="3f018"> <table name="X"/> <table name="Y"/> </table> </rom>
