Better fuel economy in CRUISE
Old Feb 6, 2011 | 10:05 PM
  #31
Hiboost's Avatar
I've never heard or seen a voltage reference table but there is an Evap Map 1 & 2 as well as a Cylinder Fuel Trim 1, 2, 3 & 4. I have no idea if anyone has tested if making changes on those tables will lean things out but assuming that the Evap Map 1 has some method of leaning things out when triggering Evap functions there is a possibility.
I'm wondering if all those maps were changed to 15.5 or 16.0 that it would shift the target values in closed loop.
Old Feb 6, 2011 | 10:23 PM
  #32
tephra's Avatar
in previous Evo's the ECU used a 0v ground to pass to the 02 sensor.
this ecu uses a 0.5v signal, so if you were at stoich you would get 1v back (assuming a 0.5v signal for stoich)
the ECU then subtracts the reference voltage and you end up with a normalised value..
so Gunzo's hypothesis is if you modify the subtractor then you can artificially change "stoich"..
but like i said this sort of feedback loop gives my brain lots of hurt
Old Feb 6, 2011 | 11:28 PM
  #33
xhomm02's Avatar
Well I do not think chnaging the reference 0v or the signal going from O2 could control the mixture. The signal is not linear (like with wideband), but changes quickly between 0 and 1V (a bit simplified). ECU leans when getting 1V and enriching when getting 0V (or negatively). This way it tries to keep stioch as average from a bit leaner and a bit richer.
Old Feb 6, 2011 | 11:34 PM
  #34
tephra's Avatar
yeh i know how it works I was just giving an example..
We wouldn't change the reference voltage, we would change what the ECU thinks is the reference voltage... ie the subtractor voltage..
I am happy to find it for anyone that has a WB and wants to test?
Old Feb 7, 2011 | 12:09 AM
  #35
xhomm02's Avatar
I know you know :-)
It would be great if the substracting in ECU worked. Unfortunatelly I do not have WB, so could not test the changes. Anyone´s help would be appreciated!
Old Feb 7, 2011 | 08:17 AM
  #36
Golden's Avatar
I can test.
Old Feb 7, 2011 | 07:21 PM
  #37
gunzo's Avatar
Don't think the reference voltage is shared for the O2 .. its shared between the front and rear O2 though ..
You can also shift the 0% value for the idle fuel trim .. helpful especially if you have big lumpy cams ..
Alot of similiarities between our ECU and the Keihins
Old Feb 7, 2011 | 07:31 PM
  #38
SiliconTek's Avatar
Tuning for fuel economy in an Evo seems a lot like those that try to use protection to last longer during sex...why bother?
Old Feb 7, 2011 | 11:46 PM
  #39
xhomm02's Avatar
Because I use the car for daily driving and while going 800km on highway the fuel economy is a metter.
Of course while enjoing the car on a curved road economy does not metter
Old Feb 8, 2011 | 11:18 AM
  #40
fostytou's Avatar
EvoM Community Team
5% of the $2000 I spent on fuel in the last year is still $100 free dollars in my pocket and a happier earth... but I'm one of those fools who runs a cat.
Old Feb 8, 2011 | 11:33 AM
  #41
SiliconTek's Avatar
Old Feb 8, 2011 | 12:02 PM
  #42
xhomm02's Avatar
I wish we had as cheap gas as you in US!
I spend about 5k USD a year (12000 miles) on gas here....
Old Feb 8, 2011 | 12:04 PM
  #43
tsitalon1's Avatar
Can we get the tables Richard?
Old Feb 8, 2011 | 01:07 PM
  #44
fostytou's Avatar
EvoM Community Team
Running e85 and driving a motorcycle that gets 44mpg helps... but foreign gas prices are definitely not an envy of mine!
Old Feb 9, 2011 | 06:07 PM
  #45
takeit2thetrack's Avatar
Hi guys,
according to theory, the best fuel economy can be achieved at lambda 1.2 (AFR about 17.6)
Has anyone tried this in low load, cruising (40-80 load, 2000-3500 RPM):
1) setting open loop
2) fuel map 1.2 (17.6 AFR)
3) increased timing due to leaner mix
EDIT 4) +increasing exhaust valve retard for higher EGR
Can this setup (due to probably high EGT) hurt vlave seats, catalysator or something else?
Martin.
Why risk expensive engine repairs for a few $$ in gas savings???? If you want good MPG buy a Festiva!!
