MR/SE/RA SST R&D soldiers on...
Old Aug 10, 2011 | 09:48 AM
RazorLab's Avatar
Did a bunch of testing this past weekend. Here's some output of that. To most it will all be gibberish but I think we are making some good strides here.
Old Aug 10, 2011 | 09:50 AM
tephra's Avatar
whats cpru stand for?
Old Aug 10, 2011 | 10:05 AM
RazorLab's Avatar
Sent you a PM.
Old Aug 11, 2011 | 10:09 PM
sstevojr's Avatar
What happened on the blue run to get that clutch slippage (I think that's what I'm seeing, odd clutch slippage well before you lifted)?
EDIT: Wait is that what it looks like when you experience fuel cut from hitting the limit?
Old Aug 11, 2011 | 10:12 PM
RazorLab's Avatar
Some clutch pressure testing.
Old Aug 12, 2011 | 09:46 AM
sstevojr's Avatar
cool
Old Aug 16, 2011 | 09:19 PM
a_decoy's Avatar
I've been continuously following your work on the SST since you did the original ROM pull and conservative tune back in 2008 on my MR. The more I'm seeing, the more complicated the TC-SST seems. If you need another test bed, just let me know.
Old Aug 16, 2011 | 10:19 PM
sstevojr's Avatar
Conversely, everything I've heard lately make's it sound like it's not NEARLY as complicated as was once thought (the physical transmission). It seems to be more likely the ECU interpolation of signals received that is the complicated aspect. I'm in no way trying to down play all the hard work that so many have committed to over the last couple years; truly impressive that this little auto' niche has such a fantastic support structure (compared to most any other automotive forum)! But then again, I certainly can't do this, so I could be totally wrong.
Old Aug 16, 2011 | 10:25 PM
tephra's Avatar
im sure once we understand it - it will seem incredibly simple...
but for the time being it does my head in
Old Aug 16, 2011 | 11:25 PM
a_decoy's Avatar
I honestly find this pretty exciting even though it's a lot of info to absorb. There are many layers to working with this transmission and discovering them is part of the fun.
Old Aug 17, 2011 | 09:46 AM
sstevojr's Avatar
It wasn't my intention to make it seem easy (it in no way is). I was more talking about the physical transmission itself; it was once viewed as some sort of witch-craft device that magically put power to the wheels, reinforced by Mitsu's refusal to even crack them open. They had this image similar to the holy grail from Indiana Jones; IF you were able to open it, you might find a golden light and God's voice booming "thou shalt not!"
Now it appears that the physical components are not alien technology, but just a really well thought out way of using existing technology (such as solenoids that clean themselves). The complex part, that leaves lesser brains a puddle of bubbling jelly, is the interpolation tables between the transmission and the engine (ECU goodness).
Keep up the good fight!!!
PS: What I think would help a lot is if we could start making replacements for the internal components (currently not available), so that as they wear down they can be upgraded. If these were replaceable then I can see a lot more people willing to push their SST in the quest to learn how it all works.Honestly, who wants to risk damaging a $10K part that is currently not serviceable if/WHEN parts wear out and/or break. Image if you couldn't replace the clutch on a Manual Transmission, and instead had to buy a whole new unit. Would you be willing to push it beyond "known limits"?
Old Aug 17, 2011 | 11:13 AM
lowkey's Avatar
Registered User
Upgraded wear items like the clutch packs are already available from SSP.
Old Aug 17, 2011 | 02:09 PM
TOralliart's Avatar
Good work. Let me know if you need to use my car for some testing.
Old Aug 17, 2011 | 05:14 PM
migs647's Avatar
HKS and Dodson make them too. We need other items available though, mainly the solenoid / TCU.
Old Aug 17, 2011 | 05:17 PM
RazorLab's Avatar
Neither are available yet. I've been waiting for the Dodson's for awhile now.
