ECU/Wiring Gurus: Need fueling adivce
Old Aug 11, 2011 | 03:52 PM
hotstix's Avatar
Originally Posted by tephra
pin 51 on the ECU by the looks of things.
you need to make sure that the Weldom thing only uses that as a signal current, not a load current...
Load current would mean varying voltage right? I believe the Weldon controller is just a signal. It cannot have varying voltage and it just colses a cirsuit once it sees 12 volts
Old Aug 12, 2011 | 09:52 AM
fostytou's Avatar
EvoM Community Team
No.. they mean that the signal coming from the ECU should only be activating the controller (like a turn-on wire for an amp). If you are feeding that current through the controller directly to the pump it will draw 30 amps through that circuit and fry the ECU.
Old Aug 15, 2011 | 06:18 AM
hotstix's Avatar
I spoke with Kim over at Weldon today. He told me that the "race" terminal on the pump controller is a trigger only, and will not draw a large current. So, I believe it would be safe to run this signal straight from the ECU to this terminal. Just wondering if there are any other saefty precautions I should put in place (ie diodes or fuses etc)
I also need to confirm that the voltage outpiut of pin 51 from the ECU is either 0/12v.
Old Aug 16, 2011 | 07:39 AM
Clipse3GT's Avatar
Eitherway, I would fuse the wiring from any of the ECU pins. Just to be on the safe side.
Old Aug 16, 2011 | 09:51 PM
tephra's Avatar
You probably cant get fuses that small
A little resistor should do the trick, stop it drawing too much current ..
mrfred
383
Jul 16, 2024 09:29 PM
Biggiesacks
Sep 13, 2016 06:43 PM
utripin
Sep 27, 2011 12:56 PM
