SST Modes, Clutch Pressure and Clutch Slip
Old Sep 16, 2011 | 09:07 AM
tephra's Avatar
Thumbs up SST Modes, Clutch Pressure and Clutch Slip
Hi Guys,
As promised here are *some* of the results from my SST Dyno testing.
Bryan@GST already posted up some data, but I figured I would post up my findings regarding clutch pressure and slip rates when changing between Normal, Sport and SuperSport transmission modes:
Normal:
Sport:
SSport:
Summary:
SSport really cranks up the clutch pressures over Sport and Normal and this really eliminates clutch slip.
Car:
2008 EvoX MR
TBE
3port
Cosworth Filter
GTX3076R
98RON
All pulls where done in 4th gear on a Mainline Dyno.
Thanks to Cobb for sponsoring my time and thanks to RoadTrackRally for the dyno time
Old Sep 16, 2011 | 09:31 AM
Supraboy1's Avatar
I need graph reading 101 for dummies. Can you explain where the torque is or is that not a factor?
Old Sep 16, 2011 | 11:27 AM
RazorLab's Avatar
Now you know why I wish I had, and really need, S-Sport on my RA.
Old Sep 16, 2011 | 02:28 PM
Jossue's Avatar
So what i got is that S-Sport is less abusive on your clutches? Am I right to get this conclusion form the grahps if so then i should be in S-Sport all the time(manual) as to not be red lining all the time?
Old Sep 16, 2011 | 03:10 PM
Hirudin's Avatar
Very interesting; thanks for posting these!
Old Sep 16, 2011 | 03:59 PM
shawnburch's Avatar
+1. Thats what Im getting from it also
Old Sep 16, 2011 | 04:24 PM
sstevojr's Avatar
I drive in Manual/Sport at times, only cuz I don't have S-Sport
So how about that TCU.....
Old Sep 16, 2011 | 07:01 PM
Beeble's Avatar
S/Sport lets them slip less, yes that's correct.
but as you also know it makes the shifts more abrupt
If you can live with it, S/Sport will technically look after the clutches better... that's what i get out of this data aswell.
Personally i either drive in Normal/full auto / granma mode , or S/Sport full kill mode
I don't think Sport ever gets engaged, except to switch from one to the other.
Old Sep 17, 2011 | 06:17 AM
korzunm's Avatar
Thanks for the info
I make my tune on alt map and will switch it on only in s-sport mode,
hope my clutch will live long life!
Old Sep 17, 2011 | 06:20 AM
tephra's Avatar
Well I have been able to tune out the slip, but thats info for another day/week/thread
Old Sep 17, 2011 | 08:28 AM
xhomm02's Avatar
It´s GREAT!
Is there a chance to enable selecting S-Sport during driving?
I usually use paddle shifting, but I get really angry when I take off and then realize I did not change the shifting mode and have to stop to change it....
Old Sep 17, 2011 | 10:23 AM
lowkey's Avatar
Registered User
Well, the abrupt changes of S-Sport might also be harder on the transmission itself and the rest of the drive-train. So it's a trade-off of clutch linings wearing faster or transmission gears, bearings etc wearing out faster, IMO.
Old Sep 20, 2011 | 11:02 PM
The__J__Factor's Avatar
Good stuff man. Always one step closer to fully understanding our cars.
Old Sep 21, 2011 | 10:37 AM
project_skyline's Avatar
Could the ECU be hacked and S-sport mode inserted cause that would be really amazing?
Old Sep 21, 2011 | 12:53 PM
Jumperalex's Avatar
Or best yet, I would love to tweak the NORMAL mode shift points to occur a little later and the SPORT mode shift points a little earlier. The two just seem a bit too far apart on the docile to agressive scale and I find myself either in NORMAL or MANUAL modes exclussively on the street.
