Is this an indication of a boost leak?
Old Sep 18, 2011 | 03:17 PM
sstevojr's Avatar
Check out this log, actual WB follows Map AFR until it goes extremely rich (afr of 10 is the lower limit of the Prosport). Is this a sign of a boost leak:
Old Sep 18, 2011 | 04:16 PM
richardjh's Avatar
Side note: There's a way to get EvoScan to put a separate scale on the right-hand-side, just for AFR. It makes a massive difference when reading graphs.
I'm not sure how I did it, but mine works! I have the following for AFRMAP and my wideband channel (data settings):
Unit: a/f ratio
Eval: 14.7*128/x
Metric Unit: a/f ratio
Eval: 14.7*128/x
GaugeMin:10
GaugeMax:15
ChartMin:10
ChartMax:15
Scaling Factor:1
I think the magic items were the "Chart..." ones, but I can't tell you exactly why. I followed someone else's instructions, and it popped up a RHS scale...
Hope it works for you too...
Rich
Old Sep 18, 2011 | 05:06 PM
sstevojr's Avatar
AFR Map is ~11.3; Actual is 10 (or less as this is the lower limit)
Old Sep 19, 2011 | 07:46 AM
fostytou's Avatar
EvoM Community Team
AFR map will almost never box correctly to AFR in your table.
Old Sep 20, 2011 | 04:23 AM
richardjh's Avatar
Completely off-topic, is boost really getting up around the 26-27psi mark on that second WOT upshift?
Rich
Old Sep 20, 2011 | 10:15 AM
sstevojr's Avatar
Yes it's around 22-23, and then spike to ~26.5. Work in progress, not dangerous level of spike (as some are tuning for 27 as the normal boost level on this turbo), but need to work on the lower bound. Right now I'm working on smoothing the High and Low timing tables.
Off topic again, what really bug me is the downshift defaulting to -15* timing. Has anyone found the table for this yet? I'd really like to make the downshift timing match the upshift (Lower Bound). Upshift is pretty dang smooth, but that downshift can buck sometimes
Old Sep 30, 2011 | 09:15 AM
Ckimjr's Avatar
Dont think its a leak....
OakosAutomotive
EvoX 'For Sale' Interior Styling
335
Oct 27, 2015 01:23 PM
OakosAutomotive
EvoX 'For Sale' Electronics / Lighting / Audio
355
Oct 20, 2015 08:07 AM
Enyth
Sep 4, 2013 12:36 PM
4G63kevin
12
Aug 6, 2012 03:07 PM
iHEARTmyEVO
Jan 25, 2012 12:51 PM
