Help help help
Old Sep 30, 2011 | 01:29 PM
NASSER400+'s Avatar
Help help help
Having some ECU issue .. Who u guys recommend for tuning in Salt Lake City , Utah
All my tuners couldn't figure it out !!
O2 sensor is not reading
Air/flow is not reading
The dealer flash it to stock
Still not reading ?
Need ur helps experts !!
Old Oct 4, 2011 | 02:45 PM
NASSER400+'s Avatar
!!!!!!!!!!!! 40 views and no respond ? where r the expert ?
what it could be ? BAD ECU ?
Old Oct 4, 2011 | 03:48 PM
Clipse3GT's Avatar
Do you have mode 23 enabled?
Old Oct 4, 2011 | 05:11 PM
tephra's Avatar
how are you doing the "reading"?
Old Oct 5, 2011 | 09:17 AM
xhomm02's Avatar
What mods did you do before it stopped reading?
Old Oct 5, 2011 | 05:31 PM
NASSER400+'s Avatar
i had a lot of mods but i tuned the car after all that in its running good ,,, by the days going my idle start acting up and then i changed the down pipe with the test pipe and i used to have an AVC-R i unistalled it but all that work i did it one time ( the down pipe and the test pipe and uninstalled the AVC-R) after that i took it to the tuner and th problem showed up ..
Old Oct 6, 2011 | 09:27 AM
fostytou's Avatar
EvoM Community Team
So it was tuned with an AVC-R and then you took it off before or after being tuned? Either way I'm thinking thats a good portion of your problem and/or whatever wires you re-spliced from the AVC-R were not done well.
