cable for virtualdyno
Old Nov 15, 2011 | 05:55 PM
thiagobr03's Avatar
hey gents, i wanted to check my hp/tq before i got tuned, what cable do i use to hook up to my comp using virtualdyno ? also if the car was previously tuned using accessport would that block me from checking it with virtualdyno ? thanks guys
Old Nov 15, 2011 | 09:15 PM
ScottSpeed21's Avatar
You just go run a 3rd gear or 4th gear, 2000rpm to redline log and plug that log into Virtual Dyno.
Wait...do you still have the AccessPort?
Old Nov 15, 2011 | 09:28 PM
thiagobr03's Avatar
nope the car didnt come with accessport, will get it professionally done soon and buy a new AP, just wanted to check and see what power its putting out right now, thanks.
Old Nov 16, 2011 | 10:43 AM
Kracka's Avatar
You should contact Cobb, you may not be able to log or tune until until the original Accessport is unmarried from the ECU. I'm sure they have a workaround which is why I suggest contacting them.
Old Nov 16, 2011 | 12:32 PM
thiagobr03's Avatar
thanks kracka, might have this fixed friday and tuned, will let you guys know how it was done, they will prolly turn the ecu back to stock and work from there im figuring right ?
