What changes to make in ECU flash after ETS intake install
Old Jan 11, 2012 | 09:29 AM
evo jason's Avatar
I don't have any experience tuning with ECU Flash but I've watched a ton of tutorials. I'm going to be installing my ETS intake this week and I'm trying to figure out if I would be able to make the changes needed for this intake myself, so I can hold off on the clipse e-tune until I have the rest of my bolt ons installed. Would I just need to change the AFR tables? Or am I missing something?
Old Jan 11, 2012 | 09:48 AM
Golden's Avatar
The standard ETS intake uses the stock MAF, so no changes are needed.
That said, your AFR should always be checked. You never know when or what may cause it to go lean.
Old Jan 11, 2012 | 02:16 PM
evo jason's Avatar
Ok, thanks. Someone in another thread said the ETS intake would cause it to run richer so I just wanted to be sure. I have the MTX-L wideband but I haven't installed it yet.
Old Jan 11, 2012 | 08:52 PM
project_skyline's Avatar
Is the ETS intake stock diameter?
Because an increase in size would require a maf scaling adjustment.
Old Jan 11, 2012 | 09:01 PM
racerx43269's Avatar
I have the ETS intake and even though it is using the stock maf housing... it still needs to be calibrated... the maf is the same but the volume of air that is now being taken in is different.
senate6268
Lancer Engine Management / Tuning Forums
703
Dec 5, 2022 02:44 AM
noobers8
May 22, 2017 08:41 PM
50joe
Cobb AccessPORT
Dec 11, 2015 05:15 PM
skills
May 4, 2013 05:07 PM
Talonmotosports
34
Jan 5, 2007 09:36 PM
