Getting started with EcuFlash, ROM 56890013
Old Jan 23, 2012 | 07:56 PM
evo jason's Avatar
I have no experience tuning but I'm trying to get started. I've pulled the ROM from my Evo and it's 56890013 according to the ROM identifying tool on Golden's website. From what I've read in my research, 56890013 isn't defined yet so I should use 56890010. I'm stuck trying to figure out how to go about doing that. Under the OpenECU\EcuFlash\rommetadata\mitsubishi\evo folder I made a copy of 56890010.xml and renamed it to 56890013.xml (also changing the file to replace 56890010 with 56890013 in two spots). After that I was able to open my 56890013 ROM, but the data is junk. Looking at a timing table the RPM axis makes no sense, so I'm guessing the mapping is wrong. I also pulled down a copy of the 56890010 hex file from http://norcalmotorsports.org/users/b...ch/ROMs/Evo10/ and I'm able to open it in EcuFlash and everything looks good.
So what do I do from here?
Edit: I found the answer on another thread. Looks like I'll be ok just flashing the 56890010 file to my ECU.
Old Jun 18, 2018 | 04:52 PM
Anthonyjh91's Avatar
having same issue with my ecu help would be appreciated I’m on 56890014
Old Jun 28, 2018 | 06:12 AM
crimson red's Avatar
Try itzwolf's xml.
richardjh
May 24, 2026 12:49 AM
jaymik
Jun 23, 2018 08:20 AM
rn520
Feb 25, 2015 05:06 PM
2011OBGSR
Mar 15, 2012 10:30 AM
jordo
Feb 29, 2012 07:59 AM
