Stock car. Only makes 17psi boost?
Old Feb 15, 2012 | 06:31 PM
11gsrevo's Avatar
Unhappy Stock car. Only makes 17psi boost?
Hi there. Dealer was recently changed my Ecu and ever since then I knew there was something wrong with my car. It literally felt like an NA car.
Today I was doing few pulls to test my boost gauge and it seems like car only makes about 16~17psi. I did 3rd and 4th gear pulls to make sure. I searched on the forums, and saw a few people claim that stock Evo should make anywhere between 20-21psi.
What do you think might be causing this? Dealer was told me prior to my Ecu change they were checked all the boost leaks, vacuum leaks and tested all the relays according to the dealership everything was fine except the Ecu.
Old Feb 15, 2012 | 06:58 PM
EXcel4600c's Avatar
where are you seeing the 16-17PSI at redline or between 4k-5500rpm???if your seeing it at redline thats because boost tapers off at redline to about 15-17psi. if your seeing it at 4k - 5500rpm thenyeah something wrong.
Old Feb 15, 2012 | 07:02 PM
11gsrevo's Avatar
yes, from 3k to 5-6k .. and yes, I know it should taper down as I rev it up. Thanks
Old Feb 16, 2012 | 04:54 PM
NZEvox's Avatar
There are a few things that will cause the ecu to run low boost as well as mechanical faults . i would get evoscan and log the ecu and check for any dtc's.
Things to log would be ect, boost , boost error correction ,wgdc, as well as the usual.
P.S I have had my ecu in and out of my car and I bent one of the pins once so maybe check those as well.
AlDim
21
Jan 11, 2014 05:34 PM
elhalisf
36
Nov 19, 2012 02:06 PM
CBRD
39
Feb 9, 2012 09:53 AM
yikez
74
Jan 22, 2011 09:33 PM
2005evo8gsr
Oct 16, 2010 02:41 PM
