Running Lean??
Old Mar 13, 2012 | 01:40 PM
The Kankler's Avatar
Running Lean??
My "Service Engine Soon" light keeps coming on and off. It will come on and stay on fit maybe 30-40 miles, then it turns off again for a while. I haven't really noticed a pattern to it. I had one of my buddies hook up his computer, and it wad giving me a fault code for the engine running too lean. I have an Agency short ram air intake on it. I cleaned my MAF sensor and it went away for a but, but more it is happening again. Is this a common problem? Perhaps you guys know of a quick fix?
Old Mar 16, 2012 | 06:24 PM
stokEd's Avatar
Quick fix? Remove intake, replace with stock. The less quick option is have the car tuned or at least re-scale the MAF for the larger intake (also requires reflashing the ECU).
Old Mar 16, 2012 | 06:31 PM
kpr's Avatar
kpr
O2 sensor
Old Mar 16, 2012 | 09:03 PM
Jookies's Avatar
I don't think the car will give you a code for anything except the rear O2 sensor reading lean indicating that there is probably an exhaust leak between the front and rear O2 sensors.
Edit: the reason I believe this is I've had friends with wideband that were running FULL lean with no CEL, though I got a rear O2 sensor lean reading when I had an exhaust leak between my downpipe and testpipe.
Old Mar 18, 2012 | 02:14 PM
momostallion's Avatar
post the code if you can.
Old Apr 3, 2012 | 08:56 PM
sdkiid's Avatar
i had same problem. it might be loose vaccum line. I bought new hose and light went away
Old Apr 9, 2012 | 08:47 PM
stokEd's Avatar
Old thread, but yeah, this is incorrect. Installing an aftermarket intake without re-scaling the MAF will result in you running lean. The OP is reporting an SES light, not a reading from an AFR gauge. Code is P0171, if I recall correctly.
asianfury01
10
Feb 16, 2013 06:11 AM
HornstarBU
Sep 5, 2011 05:14 AM
HimynameisWillzyx
May 17, 2011 03:19 PM
RoadSpike
Jun 29, 2010 03:48 PM
Jeff_Jeske
Jun 14, 2007 04:30 PM
