Cold start problem with Walbro400 & FIC1100
Old Jul 20, 2012 | 07:23 AM
wewtRallywewt's Avatar
So after about 6 MAP tweaks, my car's getting about 50% more fuel and it still can't start immediately from cold start. Help guys, seriously.
Old Jul 20, 2012 | 08:20 AM
fostytou's Avatar
EvoM Community Team
Why do you keep adding fuel? Your injectors are delivering twice as much fuel as the stock ones... you need to reduce the fueling pulse at startup from stock.
Note the X works differently than the CT9A here. The CT9A has you put the full fuel pulse in the table. The X calculates the pulse based on your other settings and has you put in an adder to the fuel pulse.
Did you use the injector latency values included with the injectors?
Old Jul 26, 2012 | 07:16 AM
*bump*
Old Aug 1, 2012 | 09:44 AM
momostallion's Avatar
try starting here:
http://www.evoxforums.com/forums/showthread.php?t=36690
i'll post my values when i can, though i have no idea if i have a cold start issue since the lows have been well over 70*F for a while around here.
Old Aug 2, 2012 | 11:56 AM
*bump*
Old Aug 2, 2012 | 12:29 PM
Kracka's Avatar
Originally Posted by Kracka
Pointless bumps, OP, doesn't seem interested in discussion, thread closed.
x2
Nniikkooss
Mar 23, 2017 01:34 AM
W0LF
Sep 15, 2016 08:58 PM
formerSTIowner
Mar 23, 2016 03:40 PM
mrfred
58
Jan 4, 2016 06:09 PM
David Buschur
Sep 8, 2010 12:34 PM
