? About 3 port & tune
Old Oct 18, 2012 | 10:05 AM
SOUL STEALER's Avatar
I have a 3 port BCS that came off my STI and I wanted to use it. I dunno the brand but aren't they all the same? The tuner the previous owner of my old car used installed it and it worked awesome. Is there a difference between the GM and others as far as current draw, output signal, etc? If it doesn't work I'll just buy a X specific unit.
That said, what would I need to change , tune wise, when making the switch? Is there a peoceduew to follow? I have an AP for tuning. Any help would b appreciated. Thankuou
Old Oct 18, 2012 | 10:35 AM
Windstorm's Avatar
*should* be the same, but if you really want help identifying it I'd post a pic.
You need to reduce the wastegate duty tables. Search the forums to find the exact instructions, I know the info is there b/c I just read it recently myself.
Old Oct 19, 2012 | 06:53 PM
Moore Auto's Avatar
Most 3-ports are the same (or work in a very similar way), you just need to know which input/output is what. Also, as Windstorm said, you will need to adjust your boost control tables (basically set passive solenoid to 0% and the reactive is the table you will tune). PM me if you need further details/help setting it up.
~Chris@MooreAutomotive
Tuner/Master Technician
okevolutionVIII
Mar 1, 2015 04:57 PM
mattnshell
Apr 20, 2014 03:42 AM
zsak
Nov 5, 2013 09:46 AM
DisgustipatedM3
May 4, 2013 09:13 PM
aka.ralliart15
May 15, 2011 04:13 PM
