EVOX - stock ECU Deatsch Werks injectors
Old Dec 20, 2012 | 12:04 PM
Malaxa's Avatar
I have a question about the stock ecu Evo X.
Deatsch Werks Injectors 21S - 03-1000
Aplication 21S Top Feed high impedance - easy to install. (Especially for Evo X.)
The stock ECU EVO X allows setting to work properly so that its partial loads and small?
Old Dec 20, 2012 | 12:41 PM
Kracka's Avatar
You can tune the stock ECU to allow for aftermarket injectors.
Old Dec 20, 2012 | 05:53 PM
Malaxa's Avatar
My question is if the injectors can be adjusted to take 14.7 AFR at idle and low loads if they behave well.
Being big is necessarily small tasks very small injection time, their spraying is correct? I mean small and medium loads.
Question is not a general one, it refers to this model injectors. http://www.deatschwerks.com/products...-1000-4-detail
Old Dec 31, 2012 | 04:25 AM
Malaxa's Avatar
It is the first time when I was influenced and made a wrong choice.
For my application are inadequate, and now if anyone is interested I can sell them less expensive.
Old Jan 11, 2013 | 05:57 AM
evokid4life's Avatar
these are great injectors ive ran them for over a year
and yes they can be tuned properly for any type of load with that said yes these injectors are harder to tune then some other injectors but if your patient you should be good
Old Jan 11, 2013 | 06:51 AM
Malaxa's Avatar
How do you explain the following:
- Engine works well for a while, then the mixture depletes.
- Why it works perfectly with other injectors 1000C?
- Why it works perfectly with stock injectors?
- Why injectors are functioning without constant with this:
http://www.deatschwerks.com/products...-1000-4-detail ?
Here, you can download a film shown in idle operation:
https://dl.transfer.ro/RALANTI2-tran...jan-66578d.rar
Mikami
Sep 27, 2014 05:28 PM
Boostin Perform
Evo X Dyno Results
23
Mar 28, 2014 11:25 AM
Shaun@AWDMotorsports
EvoX 'For Sale' External Engine / Power
12
Jan 31, 2014 08:20 AM
RU EVO
Feb 10, 2013 03:40 AM
EVO KNVL
Oct 15, 2012 03:57 PM
