2013 Evo X GSR K&N No Tune DataLog
Old Jul 9, 2013 | 06:06 PM
zebra4's Avatar
So i know there is a huge debate about intake and no tune and so forth. I just purchased a 2013 Evo X GSR from as a "new demo" from a dealership in Edmonton. It had a K&N typhoon intake and hard UICP kit installed by the dealer. They told me this is something they offer with any new Evo. Of course i had already researched that intakes should not be installed without a tune, with the exception of a few that use the stock MAF and housing. This one does. Anyway, i took it home and hooked up Evoscan to do some logs, as i do not trust what i read all the time. I do not have a wideband yet, but i logged throttle position, load, knock, etc. I was mainly looking for knock. I cannot post the logs i have until tomorrow after work, which is where my laptop is. The results though, were good as far as knock goes. I logged one 2nd gear pull, 2500-7000, and two 3rd gear pulls same rpm. In only one log did it knock, 1 count on the way to redline, and 2 near redline, this was the first log. I am not an expert by any means, and i have no baseline logs to go against, but i think it is pretty safe. In my instance anyways. I will post the logs as soon as i have access to them. I just wanted to share what i found. Any input or questions is welcome.
Old Jul 16, 2013 | 12:09 PM
Mrmcjay's Avatar
Where are the logs?
Old Jul 16, 2013 | 01:15 PM
zebra4's Avatar
I am sorry but i do not have them anymore... 2 days after logging my trusty old laptop hard drive failed and is no longer with me. I will be doing more logs this weekend (once my new laptop arrives) and i will post as promised. Sorry.
Old Jul 23, 2013 | 09:37 PM
myparkerbros's Avatar
I recently picked up a gsr from Southside mitsubishi in Edmonton. I'm new to mitsubishi and I'm curious about what I should do about tuning, I'm thinking about getting k&n filter, Tomei exhaust, and a hks Bov... I read a lot about needing a tune... Not sure about my options for programmable ecu's... I need control... I'd like to hear the k&n in person though. We should meet up sometime.
Old Jul 24, 2013 | 06:23 AM
momostallion's Avatar
you will need air/fuel ratio, that's the main thing being effected by your intake.
Old Jul 24, 2013 | 07:05 AM
zebra4's Avatar
If you are in the edmonton area then for sure we could meet up! As for tuning, i am going to see Cam at lightspeed in Red Deer for a protune via COBB access port. COBB also has base maps for different mods to use. No need for a different programable ECU or "stand alone", just flash the stock ECU.
Old Jul 24, 2013 | 07:06 AM
zebra4's Avatar
As for the logs, they are on my new computer now. Just need to be uploaded
Old Jul 26, 2013 | 05:27 PM
So the Cobb can be tuned by a pro tuner?. I'll have to do some research on the Cobb tuner, it's a good price and a lot of people have good things to say about it. How much does he charge to tune?
Old Aug 5, 2013 | 09:15 AM
Mrmcjay's Avatar
waiting for logs..........
Old Sep 1, 2013 | 08:12 PM
GP148's Avatar
By changing the afr and boost alone will make the car drive better. I have a 2013 MR and am running peak 30psi boost of stock turbo, tuned afr to give me 350hp at the wheels.
Old Sep 2, 2013 | 07:29 PM
fgafd2007's Avatar
30 Psi and only 350 whp.?.? Seems like a lot of boost for that amount of power.
Old Sep 3, 2013 | 02:55 PM
GP148's Avatar
How much power would you expect from a stock car, except for exhaust and tune? Car had dyno result of 178kw at the wheels, and went to 260kw at the wheels. Thats almost 50% increase in power with little to no laydown. BTW that is peak boost, not flatline. Car peaks at 30 and bleads down to about 23psi at 7000
Old Sep 17, 2013 | 10:01 PM
ikt's Avatar
ikt
only on E85
Old Sep 18, 2013 | 08:18 AM
marlonmck's Avatar
hey show us some photos of the car and its set up
Old Sep 18, 2013 | 03:42 PM
GP148's Avatar
Ill upload some pics when my friend gets time to take some professional shots
