Shell cam2 race gas
I actually took a second look a couple days ago and the 110 oct is leaded, but it won't anything but your cat and o2 sensors. I'm catless so the only thing I have to worry about is my wideband an o2 sensors.
Racetrack around here has Cam2. It is 100 octane, unleaded, and non-oxygenated. It is safe to mix with regular gas, and I routinely do this.
I am catless so no need to worry about it. Can you explain to me why is would be a bad thing to do? Not so worried about o2 sensors, they don't cost that much.
In case anyone wants to order this stuff, it is C10 from VP-Racing. That is safe to run with or without normal pump gas in the tank.
You should ONLY be mixing unleaded, non-oxygenated fuel with regular gas. You can expect negative side-effects with any other combination.
