campaign sc-13-004 to update the ecm software !!!
Old Jan 25, 2014 | 06:28 PM
LANEVOLIU's Avatar
I just received the campaign in the mail to flash the ecm software. but since im already tuned. there is no use for me to have this done. since i dont want to loose my tune. even tho i can reflash it with my cobb ap. but that would turn it back to how it is now.. anybody have input on this issue ?
Old Jan 26, 2014 | 07:13 PM
LANEVOLIU's Avatar
anybody ???
Old Jan 27, 2014 | 02:12 PM
maveric7911's Avatar
I have the same question.
Old Jan 27, 2014 | 02:27 PM
ModenaTwinTurbo's Avatar
An improper allowed torque threshold value sets off the mil. Can anyone confirm if it means the car allows too much torque now, or it does not currently allow enough torque?
Old Feb 3, 2014 | 07:22 PM
IRPerformance's Avatar
I got the same thing in the mail. If you are running a custom flash I see no reason to get the flash done at the dealer as it will just over-write it.
Old Feb 3, 2014 | 09:43 PM
koolzero's Avatar
I got this notice also and I am wondering if this will really over write an ECU custom tune. Can anyone else comment on this?
Old Feb 3, 2014 | 10:13 PM
Iowa999's Avatar
If I could merge threads from different sub-forums, I would. https://www.evolutionm.net/forums/ev...-x-recall.html The other name for this recall is C1311w.
Old Feb 14, 2014 | 02:28 PM
vbturbo2's Avatar
i had this done to my car and took it back as soon as i pulled out of the parking lot to reinstall the old software. the car felt like it was in limp mode. do not do this update.
Old Feb 14, 2014 | 03:54 PM
skills's Avatar
I also had work done on the car and they flashed the new ECM update. I want to flash back. ECUflash says I don't have the definitions for this ECU image (now that it's updated). Goldenevo doesn't have the definitions. Can I just flash my old map right to the ECU without this file? I want to make sure I can flash back to this new "stock" setting before re flashing my old map.
I don't mean to hijack the thread but I think this is relevant. Any help would be appreciated, thanks!!
Old Feb 14, 2014 | 04:07 PM
vbturbo2's Avatar
I work at a mitsu dealer so i was able to have them go through all the flashes to get my ecu back to stock. There was alot of maps to choose from. It took the new map just fine, I dont know which map they put back into it but it runs like it did before the update.
Old Feb 14, 2014 | 05:27 PM
skills's Avatar
Maybe this is a more general question that you or someone can answer and I'm just missing an obvious thing. I'm missing where the definitions come into play. Do I need the definitions for the new ROM ID (55590011) in order to flash my old map (55590006) to the ECU? Or will it simply overwrite the new dealer-flashed ecu?
Old Feb 15, 2014 | 04:12 AM
BakaUnchi's Avatar
you guys know that this recall activates the flash counter in the ECU right?
Old Feb 15, 2014 | 04:48 AM
packrat's Avatar
And you have confirmed this?
Old Feb 16, 2014 | 03:24 AM
BakaUnchi's Avatar
Been told by the dealer themselves
Old Feb 16, 2014 | 10:35 AM
Thomar's Avatar
Unless there is an official confirmation from Mitsubishi its considered hear-say. Dealers usually dont know much. For some reason.
