Best Tuner in CT
ok thanks guys.... I had my car done up at another shop in ct and last weekend if u go into the engine thread u will see that my bottom end went boom and rod right through the block... yippy NOT
Yeah man, you need some things however. Laptop, ECUflash and EVOscan software, tactrix 2.0 open port cable, and a wide band for Air Fuel. Tell them what you have for mods, they send a base map via email. You load it onto ECU, do wide open throttle pulls, then send back! They will tweak it and this may need to be done a few times before it is perfect.
