Used Tactrix wouldn't connect then it did
Old Apr 20, 2015 | 04:25 PM
BlackHawk_Tsi's Avatar
Heres the log:
[17:23:43.938] EcuFlash Version 1.44.4361
[17:23:43.938] OS Version Windows (unknown version)
[17:23:43.938] Qt Version 5.2.0
[17:23:43.938] 67 memory models read.
[17:23:43.938] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[17:23:44.095] 756 ROM metadata models scanned.
[17:23:44.095] checksum module "subarudbw" loaded.
[17:23:44.095] checksum module "subarudiesel" loaded.
[17:23:44.095] checksum module "mitsucan" loaded.
[17:23:44.095] checksum module "mitsuh8" loaded.
[17:23:44.095] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[17:23:44.095] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[17:23:44.095] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[17:23:44.095] flashing tool "wrx02" loaded.
[17:23:44.095] flashing tool "wrx04" loaded.
[17:23:44.110] flashing tool "sti04" loaded.
[17:23:44.110] flashing tool "sti05" loaded.
[17:23:44.110] flashing tool "mitsucan" loaded.
[17:23:44.110] flashing tool "mitsukernel" loaded.
[17:23:44.110] flashing tool "mitsukernelocp" loaded.
[17:23:44.110] flashing tool "mitsubootloader" loaded.
[17:23:44.110] flashing tool "shbootmode" loaded.
[17:23:44.110] flashing tool "shaudmode" loaded.
[17:23:44.110] flashing tool "subarucan" loaded.
[17:23:44.110] flashing tool "subarucand" loaded.
[17:23:44.110] flashing tool "subarubrz" loaded.
[17:23:44.110] flashing tool "subaruhitachi" loaded.
[17:23:44.142] J2534 API Version: 04.04
[17:23:44.142] J2534 DLL Version: 1.01.4358 Oct 10 2014 03:49:00
[17:23:44.142] Device Firmware Version: 1.15.4340
[17:23:44.142] Device Serial Number: TARDp36x
[17:23:44.142] interface close
[17:23:44.157] J2534 API Version: 04.04
[17:23:44.157] J2534 DLL Version: 1.01.4358 Oct 10 2014 03:49:00
[17:23:44.157] Device Firmware Version: 1.15.4340
[17:23:44.157] Device Serial Number: TARDp36x
[17:23:44.157] interface close
[17:23:44.173] J2534 API Version: 04.04
[17:23:44.173] J2534 DLL Version: 1.01.4358 Oct 10 2014 03:49:00
[17:23:44.173] Device Firmware Version: 1.15.4340
[17:23:44.173] Device Serial Number: TARDp36x
[17:23:44.173] interface close
[17:23:44.188] J2534 API Version: 04.04
[17:23:44.188] J2534 DLL Version: 1.01.4358 Oct 10 2014 03:49:00
[17:23:44.188] Device Firmware Version: 1.15.4340
[17:23:44.188] Device Serial Number: TARDp36x
[17:23:44.188] interface close
[17:23:44.204] J2534 API Version: 04.04
[17:23:44.204] J2534 DLL Version: 1.01.4358 Oct 10 2014 03:49:00
[17:23:44.204] Device Firmware Version: 1.15.4340
[17:23:44.204] Device Serial Number: TARDp36x
[17:23:44.204] interface close
[17:23:44.220] J2534 API Version: 04.04
[17:23:44.220] J2534 DLL Version: 1.01.4358 Oct 10 2014 03:49:00
[17:23:44.220] Device Firmware Version: 1.15.4340
[17:23:44.220] Device Serial Number: TARDp36x
[17:23:44.220] interface close
[17:23:51.079] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[17:23:51.095] J2534 API Version: 04.04
[17:23:51.095] J2534 DLL Version: 1.01.4358 Oct 10 2014 03:49:00
[17:23:51.095] Device Firmware Version: 1.15.4340
[17:23:51.095] Device Serial Number: TARDp36x
[17:23:52.365] -- loading kernel --
[17:23:52.365] -- connecting to kernel --
[17:23:52.365] kernel get version
[17:23:52.693] ECU HW part number : 1860A979
[17:23:52.708] ECU SW part number : 1860A97906
[17:23:52.740] VIN : {My VIN}
[17:23:52.740] -- unlocking ECU --
[17:23:52.740] starting session...
[17:23:52.740] requesting seed...
[17:23:52.755] interface close
[17:24:30.788] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[17:24:30.804] J2534 API Version: 04.04
[17:24:30.804] J2534 DLL Version: 1.01.4358 Oct 10 2014 03:49:00
[17:24:30.804] Device Firmware Version: 1.15.4340
[17:24:30.804] Device Serial Number: TARDp36x
[17:24:32.114] -- loading kernel --
[17:24:32.114] -- connecting to kernel --
[17:24:32.114] kernel get version
[17:24:32.442] ECU HW part number : 1860A979
[17:24:32.458] ECU SW part number : 1860A97906
[17:24:32.489] VIN : {My VIN}
[17:24:32.489] -- unlocking ECU --
[17:24:32.489] starting session...
[17:24:32.801] requesting seed...
[17:24:32.817] sending key...
[17:24:33.161] -- uploading kernel --
[17:24:33.176] .
[17:24:33.192] .
[17:24:33.208] .
[17:24:33.208] .
[17:24:33.223] .
[17:24:33.239] .
[17:24:33.239] .
[17:24:33.254] .
[17:24:33.270] .
[17:24:33.286] .
[17:24:33.286] .
[17:24:33.301] .
[17:24:33.317] .
[17:24:33.317] .
[17:24:33.333] .
[17:24:33.348] .
[17:24:33.348] .
[17:24:33.364] .
[17:24:33.379] .
[17:24:33.395] .
[17:24:33.395] .
[17:24:33.395] -- connecting to kernel --
[17:24:33.395] kernel get version
[17:24:33.395] kernel version is : OpenECU Mitsubishi M32186 CAN Kernel V1.09
[17:24:33.395] reading kernel comm buffer size
[17:24:33.395] comm buffer size set to 1024
[17:24:33.395] reading kernel flash buffer size
[17:24:33.395] flash buffer size set to 4096
[17:24:33.411] -- dumping ECU memory --
[17:24:33.411] kernel read area: addr: 00000000 len: 0400
[17:24:33.458] kernel read area: addr: 00000400 len: 0400
[17:24:33.504] kernel read area: addr: 00000800 len: 0400
[17:24:33.536] kernel read area: addr: 00000C00 len: 0400
[17:24:33.598] kernel read area: addr: 00001000 len: 0400
(Deleted logs to fit)
[17:25:05.974] kernel read area: addr: 000FF000 len: 0400
[17:25:06.020] kernel read area: addr: 000FF400 len: 0400
[17:25:06.067] kernel read area: addr: 000FF800 len: 0400
[17:25:06.114] kernel read area: addr: 000FFC00 len: 0400
[17:25:06.161] -- unloading kernel --
[17:25:06.161] kernel reset
[17:25:08.286] -- unlocking ECU --
[17:25:08.286] starting session...
[17:25:08.286] requesting seed...
[17:25:08.302] sending key...
[17:25:09.677] -- resetting ECU --
[17:25:11.114] -- reading ECU ID --
[17:25:11.239] ECU HW part number : 1860A979
[17:25:11.255] ECU SW part number : 1860A97906
[17:25:11.286] VIN : {My VIN}
[17:25:11.286] interface close
[17:25:28.240] 52680015 (214 tables) inheriting evo10base (326 tables)
[17:25:28.256] 52680022 (0 tables) inheriting 52680015 (326 tables)
[17:25:28.256] 52680122 (18 tables) inheriting 52680022 (326 tables)
[17:25:28.271] mitsucan checksum module determined checksum area to be {{0x00000000-0x000fffff}}
[17:25:28.302] using metadata XML ID 52680122 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/TephraXMOD-52680122.xml
which inherits XML ID 52680022 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/52680022 2008 USDM Lancer Evolution X 5MT.xml
which inherits XML ID 52680015 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/52680015 2008 USDM Lancer Evolution X 5MT.xml
which inherits XML ID evo10base from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/evo10base.xml
[17:25:28.302] ---notes for evo10base---
2012/10/26 [Tactrix] Updating using multiple base file data sources including base file from Golden Evo repository.
2012/11/01 [Tactrix] Moved most non-address attributes from child files to base class. Standardized file naming. Change scalings on some code modifying tables (i.e. Mode 23 - IFMode 0x05 -> 0x23) to more strongly typed bloblist scalings.
2014/05/20 [Tactrix] Tactrix definition auto cleaned|merged w/ GoldenEvoMay2014.
---notes for 52680015---
2014/05/01 [Tactrix] Original file from Golden Evo repository. If this file is useful to you, please consider donating at http://goldenevo.com/
2014/05/01 [Tactrix] Moved most non-address attributes to evoxbase.xml base class. Standardized file naming.
2014/05/01 [Tactrix] Visually examined tables for obvious errors, but no in-car verification has been done.
---notes for 52680022---
(end of Log)
The interface would just open and close several times and never read my ecu rom.
I got it to work by opening Evoscan. It connected and a ran a few logs and dynos. I came back to EcuFlash and tried again it read the wcu and errored out in the middle of reading the rom. I tried again and it worked but it 0000'd out my countdown to servicing and a u0141 dtc. Cleared the dtc and will have to reset the service reminder but everything look ok for now.
Any insight on this before I continue using this Tactrix. Is there a way to rewrite the firmware to the Tactrix?
EVIIILJ
Jan 10, 2013 12:12 AM
Nvr2old32
May 26, 2007 12:57 PM
urslo4n8
Apr 18, 2007 08:51 PM
Motaz
Jan 14, 2005 04:27 PM
