Live Tuner error opeing xmod v3 59610309
Old Jan 6, 2017 | 12:51 AM
fas-n-furyus's Avatar
Finally go a chance to try the Tephra Xmod V3 I bought. But when I open the rom file with Live Tuner I get the following error:
Process XML: :Error: The X Axis for "MAP based Load Calc #1 - Hot/Interpolated" doesn't match the ROM, Check the map & axis definition in EcuFlash!
Is anyone experiencing the same problem? if you have solved it, can you please share the solution? Any help will be greatly appreciated.
Tried to email tephra but have not gotten a response, I know he is a busy guy.
Old Jan 11, 2017 | 12:12 AM
double post
Old Feb 5, 2017 | 07:32 AM
problem solved..thanks tephra
beecee
Oct 25, 2010 07:31 AM
clipse90gsx
Jul 28, 2007 08:09 PM
zwampy
Apr 3, 2007 06:48 AM
F0rcedFed
Oct 12, 2005 11:26 AM
