AEM Boost Gauge Reading Wrong
Old May 27, 2018 | 11:29 AM
cerealkeller's Avatar
I got an AEM boost gauge installed and it seems to be reading wrong. It's showing 11 psi boost with the engine off. I pulled the line and put it back on and now it reads 4 psi positive pressure with the engine off. When it's running it isn't consistent like it should be, it bounces around all over the place. My AEM AFR Gauge reads good and they share the same power and ground source. I was thinking about getting a new sensor.
Any thoughts or suggestions?
The line to the sensor is T'd in. I can't say exactly into what, Buschur actually did the install. I'm still learning all this stuff so I'm gonna need some help with this.
Old Jun 6, 2018 | 10:04 AM
strykr's Avatar
Veteran: Canadian Forces
With the car off and the line unplugged from the back of the gauge, does it show 0? If it doesn't the gauge is out of calibration (need a new one). If it does show 0, than your pressure sensor/sender is probably bad.
If you bought it from them recently, than they should replace it as it doesn't go out of calibration quickly.
Old Jun 7, 2018 | 04:16 AM
ill message AEM. See what they say about it. thanks
thejumpoff
Oct 3, 2013 10:43 AM
ThatOneKid
Jun 30, 2012 09:46 AM
santeller
Apr 12, 2011 10:08 AM
HighwayStarX
Sep 11, 2008 12:27 PM
