Help!!!!! Unknown Rom Image
Old Apr 16, 2019 | 09:28 AM
Miguel Ortega's Avatar
greetings to all
I have a Lancer 2017 made turbo and is slightly tuned with a evo X rom that put me a tuner here in PR. I have ecusflash and tactrix openport 2.0 and it says "unknown Rom Image when it finishes reading and I can not edit the rom. someone to help me solve this error please. I am new to this and would like to learn more. Thank you
Old May 14, 2019 | 01:31 PM
SlowJoe's Avatar
5 Year Member
Check and see if your ROM is in the right folder. Should be open ECU> ECUFlash>ROMS or something like that. IF it isn't in there ECUflash won't be able to decode the ROM.
Second step would be to make sure the ROM ID pulled from the car matches your ROM file you are trying to use.
