Evoscan 2.9 logging with aem failsafe - rear o2 sensor connection
Old Jul 16, 2019 | 09:43 AM
azimx7's Avatar
Unhappy Evoscan 2.9 logging with aem failsafe - rear o2 sensor connection
Hi!
im using evo x SST 09.
currently run in tephra v1.
i have installed AEM failsafe and do connection of serial wire to rear 02 sensor wire.
in order to do this, i need to keep the rear o2 bit enabled. (wish im correct about this)
1. can any1 share how to do the rear o2 wave simulator or patch? (in order to keep the checklight from visible)
2. wideband value calculation - i have log using evoscan, but seems the value is not correct. how to do the calculation and correct address? (currently using 2380934E)
-internal ECU ID :53050109
-inherits :53050009
EDM 09 SST tephra v1
tq guys!!
