MAP Sensor & MAF Code
Old May 14, 2020 | 04:33 PM
Bpeterson02's Avatar
I recently threw a P0171 Code. I pulled the MAF sensor and cleaned it and drove about 10 mi. The light is still on and I am wondering if I should switch to the Omni 4 bar and get a new sensor. I’m at 28-29lbs go boost with full bolt ons. Any help would be greatly appreciated.
I plan to keep the car where it’s at power wise for a bit but would like to have the opportunity to push bigger boost in the future.
Old May 15, 2020 | 07:02 AM
crimson red's Avatar
If you mean that your MAF sensor voltage maxed out and you got a P0171 code(AFR LEAN), then you have to replace the intake pipe to a pipe with larger diameter instead of replace your MAP sensor.
If you mean that your boost pressure over 3 bar(=29 psi) and the MAP sensor voltage maxed out and you got a P0171 code(AFR LEAN), then you have to replace your MAP sensor to a Omni 4 bar.
Just take a log and check which is the cause of the P0171.
need_an_evo
Mar 29, 2016 09:14 AM
need_an_evo
Mar 28, 2016 02:21 PM
evoland
Dec 9, 2004 10:59 AM
fkrzo
Lancer Aftermarket Forced Induction Tech
Nov 10, 2004 11:17 AM
