Got trouble with ECU for Evo X JDM
Tried reading ECU from EVO X JDM, first by using Ecuedit, later with Ecuflash 1.42. Both get interrupted, show an error and give no effect.
I tried multiple times, as a result, my Evo won't even start now. Any ideas about this? How do I solve the problem with starting the car? |
whats the error?
restart the laptop load ecuflash load the stock rom goto the menu and say "exit programming mode" |
whats the error?
Originally Posted by tephra
(Post 7825141)
whats the error?
restart the laptop load ecuflash load the stock rom goto the menu and say "exit programming mode" I can tell tomorrow about error. Where can I get stock rom? I hadn't read ECU. |
(Post 7825141)
whats the error?
restart the laptop load ecuflash load the stock rom goto the menu and say "exit programming mode" [16:25:42.890] -- connecting to kernel -- [16:25:42.890] kernel get version [16:25:43.718] interface close [16:25:43.750] interface close Is there other suggestions? |
Today I tried to write 52360016 rom in recovery mode. It wrote successfuly, but car still with same problem - cant be started and show errors on stock display like "not much oil", "need service" etc. So same promblem without changes.
May be I need to write 52360018 rom? I don't know my stock rom, because I coundn't read it. Can anyone help to get 52360018 rom? |
tephra, do you have any ideas? :(
You need to first work out what the stock ROMID is.
Is this car an import from JDM? Ask SiC what JDM ROMID is meant to be. |
sounds like the same problem i had the ecu is locked in programming mode.
If this is a 2008 model GSR then the stock ROM would be 52360016 or 52360018, if it's a 2009 then it would be 54560002.
Seems weird that it wouldn't start after just trying to read the ROM. Maybe a problem with Ecuedit, is it even compatible with the EvoX? When you turn the key to the ON postition does the radiator fans turn on? If so, it must be stuck in programing state as mentioned above. Try loading a stock 52360018 and try to exit programing state. If successful, try to write that 52360018 to the ECU (with ECUFlash of course). The recovery method on the openecu site doesn't work while the ecu is on the vehicle. You have to do this on a bench to make it work. |
Originally Posted by SiC
(Post 7837683)
Seems weird that it wouldn't start after just trying to read the ROM. Maybe a problem with Ecuedit, is it even compatible with the EvoX? When you turn the key to the ON postition does the radiator fans turn on? If so, it must be stuck in programing state as mentioned above. Try loading a stock 52360018 and try to exit programing state. If successful, try to write that 52360018 to the ECU (with ECUFlash of course). The recovery method on the openecu site doesn't work while the ecu is on the vehicle. You have to do this on a bench to make it work. Can you send me 52360018 rom and xml? I didn't find it :( Thank you for your help! {thumbup} |
yeah thats programming mode.
you should definatley be able to open ANY EvoX ROM. then just choose "exit programming mode" from the menu. (with the IGN on obviously) no wires should need to be changed. ensure that "Atlernate flash recovery mode" IS NOT selected in the options. |
(Post 7840696)
try it again - turn ign OFF - wait 15 seconds - turn ign ON, and QUICKLY do the "Exit programming mode"
load up any stock ROM - try a 52680020 as well double check you are NOT on "alternate flash recovery mode" |
