Attn tephra<clipse3gt<acamus<xprimnt<!!
calling out Tephra.....clipse3gt....xprimnt.....and any other gearheads!!
please communicate through pm with me!! dont know if dealerships monitor these forums!! I need your help!! |
i dont do pm's :) hehe
what's the question? |
Originally Posted by tephra
(Post 8353504)
nope..
what are the symptoms? |
[quote=tephra;8353528]nope..
what are the symptoms? opps |
(Post 8353528)
nope..
what are the symptoms? dealership....cant communicate with it either.... car symptoms......wont start.....key in on position.....car goes through what i think is a continuous programming state....lights flash.....every warning pops up on dash.....dings a billion times.....it like its possesed. |
not hooked properly for bench process . . .
fried i thought it was smoking or melting away LoL most important question ! what did you do ? |
Originally Posted by E6-X
(Post 8353615)
hrmm that is odd.
I would send it to Colby first, then try the dealership option. |
I'd be surprised if it was totally dead. If you mess something up on the ROM, you can force write over it on the bench. Unless something physically happened, you should be able to recover.
Maybe run through your bench protocol with us. Perhaps it wasn't quite right. You're SURE you had the right wiring and settings in ECUFlash? What ROM were you flashing in the recover flash? |
(Post 8353504)
what's the question? tephra maybe you can send him a copy of my pdf ??? (your call mate, and i think i've lost mine and have to bench my mailbox LoL) and yes agreed send it to colby he's the GURU ! if it's totally dead you wont even see any response at all but just my guess :rolleyes: keep us posted OP and GL {thumbup} |
well the OP says hes done it properly.. twice
so its probably FUBAR'd, but better to send to Colby as a last resort before seeing it mitsu will warranty it... |
(Post 8354813)
so its probably FUBAR'd, but better to send to Colby as a last resort before seeing it mitsu will warranty it... That being said, I'd still like to confirm it was done properly. When things go wrong it's possible to miss a step or overlook something. |
yeh I know...
but like he said he thinks hes done it 100% right :) |
(Post 8355311)
yeh I know...
but like he said he thinks hes done it 100% right :) I assure you guys the bench process was done correctly. I totally forgot colby as an option! That being said.....Mitsu already has the car. And they are dumbfounded. They cannot communicate with the ecu as well. my rom id was 52680020 for those of you who asked. The position I was in didn't give me a lot of time and the car was stuck at work on a school campus and i had to get it out of there asap.....this all happened at 3 am!!! i finally had it towed to mitsu at 1pm. They say new PCM was ordered under warranty. hopefully i'll get my car backon tuesday or wednesday. ECUFLASH and Benching process, as well as mitsubishi could do nothing with the ecu because of a failure to communicate at all. How can you force a flash if ecuflash doesnt even see it......but i know it was connected properly, and took my time to do it right! and the same message that i received when it was connected to the car is the same message i recieved when it was being benched! We will see what mitsu says when they get the new one in........ |
