Installed WB today... questions..
First off, I am trying to zip tie all of the areas that come close to the drive shaft or the exhaust. I had to zip tie some areas of the WB cable to the other O2 sensor wire. Will that mess with the signal at all? My question is on the LC-1, how close can the cable come to the exhaust? It's about 2-2.5 inches away right now.
you should be fine...
on both counts... I only have the wideband + cable going through to under the car, the plug + lc1 controller + wires are in the cabin (under my footrest actually :P) |
Originally Posted by tephra
(Post 8378953)
probably, but not hot enough to worry anything...
you obviously don't want the wiring to be touching the exhaust... power/gnd's are much more important IMHO :) |
(Post 8378981)
Lc1?
(Post 8378995)
Lc1?
well just see how you go...
if things start going weird then you know you have problems ;) |
(Post 8381151)
dunno... depends on the tune.
but 11.5 is pretty popular.. any richer and the car knocks or sounds grumpy.. any leaner and its a bit dangerous but do some pulls and make sure your LC1 signal is clean and reliable. then clear the calibration and redo them to make sure your getting the same results.. then tune :) |
(Post 8381613)
14 -16 is pretty normal.
if you can find a straight bit of road and put cruise control on it should be 14.5-15.2ish.. idle same thing |
(Post 8381648)
In ATR it's just in the Edit -> Configure Options under the tab named LM-1. You check the Enable button and go from there.
Originally Posted by Golden
(Post 8384186)
