Installed WB today... questions..
Old Jun 6, 2010 | 11:24 PM
Methodical4u's Avatar
First off, I am trying to zip tie all of the areas that come close to the drive shaft or the exhaust. I had to zip tie some areas of the WB cable to the other O2 sensor wire. Will that mess with the signal at all? My question is on the LC-1, how close can the cable come to the exhaust? It's about 2-2.5 inches away right now.
Old Jun 6, 2010 | 11:52 PM
tephra's Avatar
you should be fine...
on both counts...
I only have the wideband + cable going through to under the car, the plug + lc1 controller + wires are in the cabin (under my footrest actually :P)
Old Jun 7, 2010 | 12:14 AM
on both counts...
does the body where the WB clicks into the other section get hot at all? I have it mounted under the glove box.
Old Jun 7, 2010 | 12:16 AM
tephra's Avatar
probably, but not hot enough to worry anything...
you obviously don't want the wiring to be touching the exhaust...
power/gnd's are much more important IMHO
Old Jun 7, 2010 | 12:24 AM
yeah, power and grounds are all good. I had to crimp a lot of the wiring, but all of the ones I could get to go soldered.
Old Jun 7, 2010 | 12:26 AM
tephra's Avatar
Lc1?
Old Jun 7, 2010 | 11:09 AM
Lc1?
yes the LC-1
Old Jun 7, 2010 | 04:08 PM
tephra's Avatar
well just see how you go...
if things start going weird then you know you have problems
Old Jun 7, 2010 | 06:42 PM
what's the typical AFR for a stage 2 X?
Old Jun 7, 2010 | 06:46 PM
tephra's Avatar
dunno... depends on the tune.
but 11.5 is pretty popular..
any richer and the car knocks or sounds grumpy..
any leaner and its a bit dangerous
but do some pulls and make sure your LC1 signal is clean and reliable.
then clear the calibration and redo them to make sure your getting the same results..
then tune
Old Jun 7, 2010 | 06:49 PM
then tune
just driving around the car is showing mid 15's to 16's... is that normal?
Old Jun 7, 2010 | 06:57 PM
tephra's Avatar
14 -16 is pretty normal.
if you can find a straight bit of road and put cruise control on it should be 14.5-15.2ish..
idle same thing
Old Jun 8, 2010 | 10:07 AM
idle same thing
hey man, do you know how to link up the WB and the ATR software or do I have to have 2 programs open and log them both? I haven't tried it yet because i'm waiting to get the ATR software emailed to me.
Old Jun 8, 2010 | 12:42 PM
Golden's Avatar
In ATR it's just in the Edit -> Configure Options under the tab named LM-1. You check the Enable button and go from there.
Old Jun 8, 2010 | 03:11 PM
ok, now I need to know... the WB is already blinking at me so I guess the free air calibration wasn't enough... can I recal it while it's in the exhaust?
