Installed WB today... questions..
Old Jun 11, 2010 | 07:23 AM
  #46
Methodical4u's Avatar
Originally Posted by CatalystGod
did you take your leg off the gas pedal before trying to recalibrate, you're supposed to do that. I think its for 5 seconds, check Innovate's website, they should have it listed in the LC1's manual.
yeah I did... I actually let it coast for over 5 seconds, but I was pushing the button and holding it in instead of just pushing it for a second or 2. I'll have to try that next... I just would like to know what i'm doing to throw it out of calibration... perhaps it's what tephra said and that I need to get all of the software stuff straight with it, i'm trying to wait patiently for the serial to usb cable to come in so I can actually see what it's doing.
Old Jun 11, 2010 | 08:09 AM
  #47
Golden's Avatar
I think it throws it out of calibration when you plug / unplug it while it is powered on.
Old Jun 11, 2010 | 08:25 AM
  #48
yeah, but the thing is, I don't have it plugged into anything... it was reading fine, 16's and 17 range and then I turn the car off sometimes and it's out of calibration... hopefully the software will do something to stabilize it... in the meantime I will check on all the connections and the sensor itself to make sure it's in there tight enough.
Old Jun 11, 2010 | 08:43 AM
  #49
derekste's Avatar
doing a re-cal typically resets the fuel type for AFR determination to a random number.
after you re-cal properly, go in to LMprogrammer and make sure it is set for 14.7(Gas) and not something custom.
Old Jun 11, 2010 | 05:44 PM
  #50
tephra's Avatar
^ yup.
if your finding its resteting itself randomly (and you are totally not connecting the little serial plug) then you need to dbl check your power supply
Old Jun 11, 2010 | 06:03 PM
  #51
Originally Posted by tephra
^ yup.
yep, got it set today, turned the car off, when I got back in it read nothing but 9's... I don't get it, but i'm not happy with the product AT ALL. Hopefully it's something i'm not doing correctly.
Old Jun 11, 2010 | 06:05 PM
  #52
tephra's Avatar
use LMProgrammer, if your gas type goes to Custom then you know it's loosing its calibration.
Old Jun 11, 2010 | 06:09 PM
  #53
yeah I will as soon as my cable comes in so I can check it properly.
  #54
tephra's Avatar
what are you using for power/grounds?
Old Jun 11, 2010 | 06:22 PM
  #55
for ground I am using the bolt under the dash that's to the right of the fuse box.... then the ground i'm using the reverse light fuse, with a fuse tap that's soldered to the power wire.
Old Jun 11, 2010 | 06:26 PM
  #56
tephra's Avatar
was one of those meant to be power?
Old Jun 11, 2010 | 06:32 PM
  #57
tephra's Avatar
also when you get LMPRogrammer - check the firmware you are running...
Old Jun 11, 2010 | 06:44 PM
  #58
the reverse light works when the ignition is in the "on" position.
Old Jun 11, 2010 | 06:52 PM
  #59
tephra's Avatar
ok - your post said ground thats all
Old Jun 11, 2010 | 09:02 PM
  #60
Golden's Avatar
Yeah, I think he meant for power he is tapping that fuse. It's a bit hard to tap a fuse and get a ground.
