Installed WB today... questions..
I know the cable is working because the computer is picking it up... the car just isn't connecting... so at least it's not a cable issue... that I know of anyway.
anyone close by to you that can lend you a cable?
If LMProgrammer/LogWorks doesn't connect at all (and the light doesn't flash) I would be inclined to say the USB->Serial cable is looking dodgey
yeah, I mean I don't really know what to do about it though... aside from going to my local electronics store to see if it will work... and they want 38.00 for that cable... I paid 3 or 4 on ebay... which is maybe why it doesn't work.. I don't know wtf to do.
Check fuse #12 (red, 7.5A), you might have blown it when you were fooling around in there. I did the same thing and got the airbag code, as well as ASC service, etc... Are you able to get to the O2 sensor, ie dropping the TP/HFC? If so, drop it and turn the car to on (not cranked) and put your hand near (not on) the sensor. If it warms up you'll know it is wired correctly.
