Installed WB today... questions..
yes, but its a bit tricky.
find a hill or jump on the highway, rev upto 4500 and then wait for fuelcut decel, then wait another 10 seconds or so for fresh air to be pumped through the engine, then do the recal..
i always check the IPW log afterwards to ensure no fuel was being injected during this proceedure
Yes. Hollywood says that he drives down the road, lets off the gas so the engine is engine braking and then hits the calibrate button. When you are engine braking, the injectors are off, so fresh air is flowing by the sensor. I think you could also let the car sit over night and press the button before you start the car.
There was a thread about it on the other forum. I'm just typing what I remember off the top of my head. I don't have an LM-1... I have a AEM, so no real world experience with it.
ok, so I went to plug into the computer but guess what? The cable that came with the LC-1 won't fit in any of the ports on this thing... do I need it or will the dongle log it?
Second question is, if the dongle will log it, which one of these logging parameters do I need to log? There's LM-1 this and that aux 1 2 3, recording... which one is the one I actually need to log the AFR correctly?
EDIT: NM, saw you were using ATR. I got no clue about ATR. Only way to hook the LC1 to the PC that I know of is using the serial-usb converter.
You'll need a USB to serial dongle. The best buy one will work on the PC version of evoscan, I'm assuming that's what you're using to log?
http://www.accessecu.com/support/doc...bishi_EVOX.pdf
page 6
you need a serial to USB converter... why is this so difficult?
page 6
1) LC1 has a 2.5mm female audio jack
2) Dongle that comes with LC1 has male audio jack that goes into the female end on the LC1.
3) Second end of the dongle is a male RS232 interface.
4) Buy a USB to Serial (female) converter from Best Buy or any other store and hook the RS232 connectors to each other.
5) Plug the USB end of the converter into the laptop.
Have you successfully done this?
The OBD dongle you are talking about is the OP2.0 connector I assume. Are you trying to log the LC1 using the OP2.0 connector or a laptop? You can only do either/or.
EDIT: Damn! I keep forgetting you're using the AP. Only the last statement does not apply to your case. Basically LC1 connects to a USB port and the OBD dongle connects to a different USB port. You need 2 USB ports basically. If ATR is anything like Evoscan, it will overlay the OBD readings and the LC1 readings.
page 6
page 6
You're really confusing me here. I'll try one more time.
page 6
page 6
