Why doesn't my "RPM Per MPH Xover"-setting work?
Hey guys!
After installing my 3-port I'm tuning the boost and it works great, but the gear based setting doesn't work... I set it to "80" (it's a MR), yet in 3rd gear he still uses the "high gear range" tables!?!? What could be the cause for this? EDIT: Just checked the definitions and they ARE set for MPH, so it SHOULD work... |
I think I just found my answer in the following thread... Wrong definition address...
https://www.evolutionm.net/forums/ev...t-control.html |
Yeah, I had that same problem with wrong definition address too when I first posted that thread.
If you need me to find the correct address for you, let me know.
Originally Posted by Golden
(Post 9196897)
So thanks, either way! Actually I'm already back from finishing up the Wastegate Duty Cycle and BTEL maps. Worked pretty well on the Autobahn in fifth gear... Tops at about 210kph/130mph. I was lucky as well. Every time I had corrected the map and drove back onto the Autobahn and IMMEDIATELY had the perfect hole in traffic to do a complete 5th gear pull. 3 pulls total. All done for now! Now off to switch to summer-tires and optimizing corner weights... I call it Evo-Kaizen... :-D |
| All times are GMT -7. The time now is 10:54 PM. |
