AEM inline controller serial logging
My com 1 is enabled, I am going straight to serial port, my controller is wired correctly, I have made sure i am on the correct pins in the dsub, My green light is solid, but I can not for the life of me get it to work with ATR. Plus the ATR crashes almost every time I try to get the dashboard up. Anyone have any ideas?
Test it with hyperterminal or putty (the puttytel version) using the serial section. The AEM manual has the settings you need.
Originally Posted by Golden
(Post 9689979)
It will write afr values you your screen. Lots of the, really fast.
(Post 9704348)
Do you have the com ports setup correctly on your computer?
(Post 9708340)
I double checked all connections, ran jumper leads to the battery, green light on the controller is on but I have only seen the red light flash one time. (was told this was the heater circuit) I have looked over all my wiring, made sure the sensor was plugged in and seated in the connector all the way. When I try to use hyperterminal, it just shows up as jumbled symbols. I unplug the serial connector and they stop so I am assuming its picking up something maybe not?!? I am using accesstuner race software and both on the dashboard and in the log file all that shows up is 0.00 constantly. I am down to pulling the sensor and or trying to get some sort of warranty? which i doubt AEM or MAP will do. Inputs from anyone would be appreciated, I usually am able to figure this out, but this one has me totally stumped. |
Jumbled symbols means that you don't have the port setup right. Check the manual. It should have the settings you need. Like the com port speed.
(Post 9710055)
----- Also, please note that there is a thread that looks quite a bit like yours (despite ATR vs Evoscan) and a few other, very related posts: https://www.evolutionm.net/forums/ev...d-evoscan.html https://www.evolutionm.net/forums/ev...headaches.html ----- OH, and your threads. Please don't clutter up the forum if you can help it: https://www.evolutionm.net/forums/co...headaches.html https://www.evolutionm.net/forums/ev...l-logging.html |
The inline controller uses a different baud rate than the old AME UEGO.
