WORKS Evolution X Air Filter
I said "looks" like it. Hard to tell from a 2D picture. In any case, I think the filter costs too much. What are the power gains for said filter?
The Works filter has a bit more working area than the K&N on the 8/9. I'd assume this carries over to the X too. On the 8/9, K&N's have shown 3-5whp peak, with up to 8whp max gain from what I've seen. So figure a little bit more for the Works. It's probably a reasonable assumption that the gains on the X will be similar to those on the 8/9.
As for cost, it's only too expensive if supply is exceeding demand. Considering there was more demand than supply on the filters for the 8/9, the price is not too high according to the market.
Well, I can see that there's about a 20-30 hp gain, which is inline with the gains seen by intake systems from the other manufacturers because of how rich the car is from the factory. SPDARacerut, look at all of the tuning tests from shiv at vishnu, AMS, and AGP. They all say that intakes gain about 30 hp because the X runs INCREDIBLY rich from the factory. The gains that the X are making with simple bolt ons is blowing away what the 8 and 9 made. Man, how could you not know this? It's all over the forums.
BTW Jamie, could you post the actual numerical gains, and test a k&n to compare. Because no offense, but if the k&n makes the same hp for 40 bucks than that's where my money is going to go until full intake kits are available from ams and turbo trix, OR YOU GUYS, if the parts make comparable gains and look good. Hey underhood style is important too, guys.
Fair enough, but could you post the numerical gains of the filter? I can see from the dyno graph that it's somewhere around 20-25, but can't tell for sure. Oh, and BTW, the K&N drop in replacement is the exact same as the regular lancer, as I believe it's the same exact size filter. Check it out. Oh, and until I get an intake system for the car, a drop in sounds nice to tide me over for a bit. I will consider your product.
Yes, the Lancer and EVO are sharing the same filter just as with the previous Lancer/EVO, but I still haven't see any other applications available aside from WORKS and Mitsubishi.
