Nisei Pipes for the win!
K, You cant use the AEM pipe that comes with their box, but the AEM box will fit with the Inlet pipe from Nisei for those that where interested at all. I will post pics as soon as Kevin get all this stuff to me and I can get it all installed. Im also waiting for a Stealth FMIC I have ordered from Perrin, so I can do it all at once. I dont want to take the bumper of twice, so it may be awhile for pics. I hoping to have them both before the end of the month though. I want to say thx to antics for trying stuff out on his car for me. Kevin told me they used your car as the guinea pig so thx. I cant wait to get my stuff.
Mmm, I don't think it can be used with the aem box because the aem box 's inlet pipe goes inside the box to connect to the cone filter. The nisei inlet pipe is a stock style pipe that clamps over the maf housing. The maf housing on the aem isn't like the stock setup where it's a separate unit, it's built into the aem's inlet pipe. There's no way to make this work.
im waiting for my call from kevin as well, it seems like if you use the nisei intake pipe instead of the aem black intake pipe it should work fine. hopefully i get some news soon
When they prototyped the Nisei intake pipe, they made it to stock specs so it mates to the stock MAF housing and from there, you can use a factory box, an ARC box (like how im running mine), or any cone-type filter for that matter.
With the AEM kit, AEM uses their own rubber intake pipe that is shorter than the factory. Followed by that, is the AEM metal MAF housing pipe that is longer (by 2 inches or so) than the stock MAF. Botht he AEM MAF housing and stock MAF housing appear to be the same diameter.
So, we were able to fit the AEM box as well as the AEM cone inside the box. Everything lines up, but the only thing is: You can't use the AEM MAF pipe unless you want to modify it by cutting it shorter by 1 1/2" or so... In order for you NOT TO MODIFY the AEM MAF pipe, you can actually run the stock MAF adapter pipe and the AEM cone filter will actually connect to it. Everything is still direct bolt-on, you simply just omit the AEM rubber intake and the AEM metal MAF pipe...
There will be pictures and updates on this....
updated info: http://www.nisei-evo.com/forum/viewtopic.php?p=818#818
antics, do you think there is a difference between the aem MAF housing and the stock one? im assuming you saw the kit since it was on your car
Please don't speculate on this unless you own a nisei intake pipe and an AEM box...
The Nisei intake pipe CAN BE USED with the AEM box. Some of the components of the AEM kit will not be used such as their rubber intake pipe, and their metal MAF pipe, but the BOX and the AEM Cone filter all BOLT ON without any issues.
Sounds more complicated than it really is.... Heres a couple of pics:
You can read all about it here...
http://www.nisei-evo.com/forum/viewtopic.php?t=632
oh damn, you posted this just as I was posting... lol
Aside from the factory being plastic, and the AEM one being metal and pretty... from "eyeballing" the two side-by-side, I saw no difference at all in the diameter size of the MAF housings.... only difference being the AEM MAF housing was longer than the stock one... I believe Nisei was going to measure the inner diameter a digital gauge reader to confirm....
Just as an FYI, the stock MAF starts off big at the entry and exit but it necks down to about 77mm where the sensor reads the signal. Just for reference the AMS intake is about 82mm all the way through in their one piece turbo to filter 3" tubing. These measurements all being inner diameters and I'm not sure about the AEM measurements.
While 5mm difference seems minor, the intake does lean out the airflow readings by a good chunk since it's about 6% difference in diameter. Much of the gains of the intake are from leaning out the AF ratios.
I'll be damned, I didn't think that you could use the stock maf housing with the aem box. I will say this though, if you're gonna use the AEM box in this type of setup then why not just use the stock box with a drop in? Intakes make most of their power in the filter element leaning out the air fuel, just the same as an oversized maf can trick the ecu into going into a lower load cell and thus leaning out the fuel mixture and running more timing. However, once ecu tuning comes into play, these gains are no longer present.
Dyno4mance just proved this by showing that the works drop in filter netted about 10 whp on their low reading dyno dynamics (the gains read higher on other dynos), but after a tune it made the same amount of power as a stock paper filter. As the power levels are raised then I suspect the paper filter element might become a restriction, so a simple drop in is a good way to go since the box itself isn't a restriction at all. Either way, there is some power to be made in the UICP and possibly some spool improvement to be had with the inlet pipe. Plus it SO nice that it hides the bov hose! Nisei = super clean. Nisei FTW.
I will say that after adding the Nisei hot pipe and the works filter I did a run on the same tune the earlier in the day netted 287 whp, in the new configuration with the same tune I got 303.4 whp. AFR lean way out (like 12.2:1) over the previous configuration, more so than I would attribute to the filter. After getting the fuel back where it should be I put down 300 whp a gain of 13whp just from adding the Nisei hotpipe and works filter. I think the gain was due to increased VE as I put the fueling back where it should have been and still gained 13whp.
-Bruce
No where in my post about the filter testing did I say this. I have speculated on this in the past and still do to to some extent, however I have not tested this theory yet and to be honest it's too late now as I have already added the Nisei hot pipe.
-Bruce
-Bruce
I think you were thinking of one of Noize's posts about tuning results. I certainly did test the drop in filters last weekend and post the results. However, I didn't say in that thread there were no gains after tuning. I couldn't say that because I didn't test that specific case.
I can say that the addition of the works filter and the Nisie hot pipe netted 13whp on our heart breaker of a dyno after bringing the afr back down to where it was before hand.
No, I didn't.
Anyway, back on topic.
Go Nisei
Go Nisei
