Forge WGA
Old Oct 1, 2008 | 10:34 AM
DVDee's Avatar
Forge WGA
How are people pre-loading the spring when installing this part or just leaving it the way it comes? If it's being pre-loaded how many turns are you guys using and what is a general recommendation?
Old Oct 1, 2008 | 04:47 PM
Hiboost's Avatar
It seems that you just want enough preload to make it snug from my testing:
0 turns = you can barely slip the eyelet onto the WG pin, may leave the WG open a crack if not preloaded at all. Allowed 21 PSI minimum boost.
1/2 turn = Allowed 22 PSI minimum boost for my car, wasn't 100% sure it had enough preload but should be fine.
1 turn = finally settled on this setting which allows 23 PSI minimum boost, spool is fast and I can set boost from 23-26 psi
2 turns = I tested this setting to see if it would help the 6k rpm+ range of the stock turbo, Minimum boost went to 24-25 psi and held 25 psi to 6000 rpm but dropped sharply past that and was still 19 psi @ 7500 rpm.
