did I get this right? where the boost pill goes
Old Oct 21, 2008 | 12:15 AM
ablaze's Avatar
Question did I get this right? where the boost pill goes
this's with regards to where the boost pill is located on a STOCK setup. I was mucking around and forgot which way the original hoses were connected. and you won't believe how much conflicting info there is in the forum
please see the pic below and the hose in question. (Noize's pic: hope you don't mind!)
did I get the orientation right? ie. the hose with the boost pill goes to the actuator? and the hose with the red line goes to the turbo outlet? (pardon the mouse-drawn-words )
Attached Thumbnails did I get this right? where the boost pill goes-mbc002.jpg
Old Oct 21, 2008 | 12:43 AM
ablaze's Avatar
or is it like in this how-to:
http://www.evoxforums.com/forums/showthread.php?t=2925
, with it the other way round ie. the hose with the pill goes to the turbo outlet??
Old Oct 21, 2008 | 06:25 AM
Guru's Avatar
The pill always goes on the hose connected to the compressor outlet.
Old Oct 21, 2008 | 07:29 AM
ablaze's Avatar
so the picture I had in the first post is wrong?
Old Oct 21, 2008 | 10:58 PM
STi2EvoX's Avatar
The pill has to go to the side that connects to the wastegate. It's job is to slow the flow of boost pressure on the wastegate actuator so that the boost control solenoids can vent out the excess air to maintain a better taper. If you switch the pill around then the wastegate will vent the air faster than the solenoid can vent it out and your taper will be much worse. The picture is right.
Old Oct 21, 2008 | 11:24 PM
RazorLab's Avatar
Pill is on the pressure source side always, your theory is correct, but your side isn't.
Hose with red goes to WGA
Old Oct 21, 2008 | 11:33 PM
STi2EvoX's Avatar
woops.
Old Oct 22, 2008 | 01:24 AM
ablaze's Avatar
so the pic is wrong?? ie. on a stock setup, it should be the other way round (depicted wrongly in my 1st post's pic)? STi2EvoX, I think it's your posts scattered around the forum that've been confusing me!
has anybody tried switching it around so that it's connected like in the 1st post's pic? wonder how that'd affect boost response.. hmm..
dan-lincs
Jul 5, 2016 01:02 PM
m3typer
Nov 3, 2012 01:22 PM
aiden1983
10
Mar 11, 2009 12:37 PM
delivery
May 22, 2006 04:54 PM
RalliArtEvoVIII
Dec 24, 2004 03:38 PM
