Maximum boost with stock turbo and internals?
Old Nov 14, 2008 | 03:00 PM
LVSBB6's Avatar
What is the highest boost you can run with stock turbo and 4B11 internals thats considered safe for the motor and efficient for the turbo?
I know stock is around 21.75 psi, how much more boost can you dial it safely?
Old Nov 14, 2008 | 03:40 PM
Rguy's Avatar
Ive been running 25psi tapering to 18 by redline and havent had a problem. BTW, stock spikes to 23psi and tapers to ~15.
Old Feb 7, 2011 | 02:14 PM
skylngtr22's Avatar
how long have you been runing this set up? and what supporting mods do you have?
im currently tuned for 23 tappering to 16~
Old Feb 7, 2011 | 05:06 PM
ToFastforU_99's Avatar
Check out the Evo X dyno section there is a lot of cool information on ppl running stock blocks and turbo and what they are pushing.
Old Feb 7, 2011 | 05:27 PM
Kracka's Avatar
I'm currently at 26.5 psig peak tapering to 19.
Old Feb 8, 2011 | 05:43 AM
skylngtr22's Avatar
Thanks guys
Old Feb 8, 2011 | 12:14 PM
DepoRacing's Avatar
I'm hitting 30 tapering down to 22, with full stock exhaust. i have boost pill
Old Feb 8, 2011 | 03:18 PM
ImEv0's Avatar
when are you suppose to use boost pill?
Old Feb 9, 2011 | 08:10 AM
tlsole's Avatar
Im tuned at 26, spiking to 27-28, tapers down to 19-20psi by redline (3-port).
Old Feb 9, 2011 | 08:46 AM
Fidget253's Avatar
tl, whats your dyno?
Old Feb 10, 2011 | 02:54 AM
EVOXTIMES's Avatar
I boost at 30 psi no problem. Only thing that sucks is the stupid warning that's pops up.
Old Feb 10, 2011 | 06:42 AM
tlsole's Avatar
I did a road tune, so no dyno numbers..
Old Feb 10, 2011 | 08:02 AM
derekste's Avatar
I wouldn't run more than 30psi (on E85)... and even then I think that is pushing it.
Be very sure that whatever you are spiking, that it never goes higher than that (i.e. when weather changes). The stock turbo is capable of making over 34 PSI. No, you aren't going to be making more power at that level, but it will be more than enough pressure to vent your cylinder block.
Old Feb 10, 2011 | 08:03 AM
derekste's Avatar
there's a fix for that.... and I found that warning didn't usually come on until 31psi... so be careful
Old Feb 10, 2011 | 07:27 PM
TJ4EVOTURBO's Avatar
Some good info
