Will these pipes be compatible??
Old Nov 22, 2008 | 07:30 PM
ChimpEvOX's Avatar
I have EVO X buschur upper and lower intercooler pipings. I have ordered AMS intercooler will it work out fine??? any input would be greatly appreciated.
Old Nov 22, 2008 | 07:32 PM
Rguy's Avatar
I think all those parts were designed to fit to stock components, so therefore they will all bolt up to each other just fine.
You should be good to go.
Old Nov 22, 2008 | 07:34 PM
ChimpEvOX's Avatar
thank you
Old Nov 22, 2008 | 07:45 PM
gotrnet's Avatar
the buschur racing lower intercooler piping is NOT a stock replacement. it is designed to work with there intake only (unless they did a redesign since i got mine in august). you will have no issues with the intercooler but you will most likely have intake issues if you are not running a buschur racing intake. i ordered thinking it was a stock replacement as well but then had to use some PVC 90 degree bends to get the BOV to hook into my ams intake. tried putting back on the stock one and the piping didn't work either. but as for you question, yes it will work with the ams intercooler.
