Downshifting an MR
Old Dec 16, 2008 | 08:43 AM
WAM's Avatar
WAM
Downshifting an MR
What happens if you manually downshift an MR too early while breaking?
1. shifts anyway which could hurt the car
2. delays the downshift until revs are safe and then downshifts
3. ignores the command completely
4. other?
Old Dec 16, 2008 | 10:10 AM
KGHtheII's Avatar
4. other?
I'm pretty sure that if you downshift wayy too early, it will beep at you and refuse. Might want to get a second opinion on that however. I have downshifted and it has redlined before though, so I am not sure what the threshold would be if I am correct about the beep/refuse.
Old Dec 16, 2008 | 10:58 AM
navidf's Avatar
If it is outside the safe parameters, it ignores it and double beeps
Old Dec 17, 2008 | 10:50 AM
verkion's Avatar
Beep Beep...and does nothing. I run into this quite a lot because in normal mode it takes a little time for the paddle to respond. Shift lag if you will. So sometimes, I hit the paddle, and nothing happens for a bit then I hit it again...of course its shifted by the time I hit it again so it beep beeps at me. The lag goes away in sport and S-Sport mode.
verkion
