Spark plug replacements
Old Jan 7, 2009 | 06:05 AM
DueceEVO's Avatar
I have been having a few issues I think caused by some plugs that have taken to much fuel from the stock tune and I wanted to know what replacemnt plugs I should get for the 2008 X GSR. I dont really want to go to so i will most likly be going to NAPA. Thanks
Old Jan 7, 2009 | 08:08 AM
RussellM's Avatar
Plat Vendor
Ill give you a link to the Mitsubishi Plugs even though you are being anit-Mitsubishi.
http://www.mitsubishiparts.net/cart/...&pn=1822A021*4
Old Jan 7, 2009 | 10:07 AM
DueceEVO's Avatar
Does NGK make plugs for the X, if so whats the part number
Old Jan 7, 2009 | 10:13 AM
RussellM's Avatar
Plat Vendor
Mitsubishi's are NGK's
Old Jan 7, 2009 | 10:21 AM
DueceEVO's Avatar
I figured they would be, do you have the NGK part number cause I just talked to Mitsubishi and they said they couldnt get them until next week. I checked NGKs website and they are not listed. They auto parts store only pulls up some Autolite Iridiums
Old Jan 12, 2009 | 08:43 PM
B00ST3DEV0's Avatar
http://www.vividracing.com/catalog/e...4206_4248.html
hks spark plugs idk if your interested
Old Jan 13, 2009 | 12:10 PM
Touge Factory's Avatar
If NGK is indeed the OEM make spark plugs, there should be a stamped part # on the plug. either on the hex part or the ceramic part.
Pull one out and see if you can get the part #. Contact NGK and they'll tell you which plug is a direct replacement.
Unfortunately, our Evo X is in storage...so don't have access.
Old Jan 13, 2009 | 02:56 PM
RussellM's Avatar
Plat Vendor
Originally Posted by touge factory
if ngk is indeed the oem make spark plugs, there should be a stamped part # on the plug. Either on the hex part or the ceramic part.
Pull one out and see if you can get the part #. Contact ngk and they'll tell you which plug is a direct replacement.
Unfortunately, our evo x is in storage...so don't have access.
ngk# ilkr8e6
Old Jan 13, 2009 | 03:13 PM
zTargeTz's Avatar
is that like, the NGK BPRE6 ? Great plug for a stock boosted X, I've run them in all my stockish 4g63's, before i step up a couple of heatranges for higher boost.
Old Feb 28, 2009 | 01:55 PM
scottatyamaha's Avatar
bump....
Old Feb 28, 2009 | 04:08 PM
tomatoEVO's Avatar
i have HKS super fire racing plugs, still haven't installed yet. they're the only aftermarket plugs i've seen for the X thus far.
Old Feb 28, 2009 | 06:09 PM
philamthebest's Avatar
HKS M-series
Old Mar 1, 2009 | 07:44 AM
I just want to know if there is a NGK copper plug we can run.
Old Mar 1, 2009 | 10:06 AM
robh's Avatar
don't know if this helps or not but ill put it up for you all
http://www.ngk.com/sparkplug411_manu...nufacturerID=1
Old Mar 5, 2009 | 09:31 AM
Did a little research and discovered that factory NGK plugs are only availible from a Mitsubishi dealer right now. My local NAPA guy called NGK directly.
