Boost and vacuum numbers ??? WHat you guys have?
Old Feb 3, 2009 | 09:56 PM
EVOXSILVER's Avatar
Just wondering what you guys see on your boost gauge on the vacuum side, i have -18, does it sound right?
I can also boost up to 21 psi without any sort of boost control (HKS EVC 6 EBC turned off and stock boost solenoids disconected.)
My mod list is:
Forge WGA
HKS EVC 6 EBC
ETS Intake
ETS 4" IC
ETS LICP & UICP
ETS 3" Turbo back exhaust
Old Feb 3, 2009 | 10:19 PM
PR_Mivec's Avatar
21 psi is the forge doing its job.... on the stock wgs you might see 13 to 14psi
and vac is about right... 18 to 15
Old Feb 4, 2009 | 04:15 AM
S2K2EVOXGSR's Avatar
looks about right to me.....
Old Feb 4, 2009 | 05:49 AM
boostin20's Avatar
Stock I have 18inHg and 15psi. I double checked with my modis and my numbers are pretty much the same (my boost guage can't really display less than 1inHg/psi differences)
Old Feb 4, 2009 | 10:33 AM
matias04374's Avatar
When I start the car and it warms up I have vacuum at 18 but after driving for a bit it will drop to as low as 20 is this right?
Old Feb 4, 2009 | 02:25 PM
EVOXSILVER's Avatar
For the vacuum i think the highest the best .... as for boost
So if between -15 and -18 is ok then i'm happy. Thank you guys.
Old Feb 4, 2009 | 03:16 PM
Talon_66's Avatar
Ive seen mine as low as -22, but the gauge could be off.
Old Feb 4, 2009 | 04:47 PM
boostin20's Avatar
Mine also drops to 22inHg every time I leave it in gear and decel.
Old Feb 5, 2009 | 02:22 PM
EvoX2NR's Avatar
mine is around 21-22inHg at idle... drops to about 24inHg on decel...
Old Feb 5, 2009 | 03:25 PM
Talon_66's Avatar
I checked mine last night. Im the same as u
Old Feb 5, 2009 | 03:36 PM
EvoX2NR's Avatar
probably because of the same gauge... I have the prosport premium
Old Feb 6, 2009 | 06:59 AM
GrkBallaG's Avatar
15psi? Do you have a boost leak or something? stock is 21psi.
Mine is 20inhg for idle and i hit about 24psi
Old Feb 6, 2009 | 07:09 AM
boostin20's Avatar
Maybe mine wasn't made on a Wednesday.
Old Feb 7, 2009 | 07:25 AM
i8fizh's Avatar
I think he meant 18-15inhg?
pgevo
Aug 4, 2015 05:17 AM
ZeRoMaX
Jul 9, 2015 04:06 PM
BEISSEN
Apr 18, 2011 07:19 PM
alby988
Jan 9, 2009 05:40 PM
ctx2000
11
Oct 26, 2005 09:40 PM
