Help Spark Plug re-Gap needed?
Old Mar 1, 2009 | 09:34 AM
kirkklau's Avatar
Question Help Spark Plug re-Gap needed?
i am running meth and okada cdi ignition with my Red.
is regapping of the plug needed?
thanks guys
kl
Old Mar 1, 2009 | 10:04 AM
robh's Avatar
what gap are you running? how much boost?
Are you getting spark blow out
If so you just need to close the gap a bit thell you dont get spark blow out
Old Mar 1, 2009 | 10:38 AM
cfdfireman1's Avatar
Ask your tuner.
Old Mar 1, 2009 | 10:52 AM
kirkklau's Avatar
will run peak 29psi and hold 26 psi at the top.
running stock gap but don't know how wide is the stock set up.
i will check with my tuner and see if there is a problem when he is tuning the car.
kl
Old Mar 1, 2009 | 12:07 PM
Clipse3GT's Avatar
Take out a spark plug and check the gap.
I would assume 0.040-0.044, you can always decrease it a bit to something like 0.036. I doubt you are getting spark blow out.
