So has there been any other problems with long downpipes?
Old Mar 3, 2009 | 12:18 PM
brainhulk's Avatar
Just saw the other thread with the crack in the weld. Anybody else have problems or heard of any?
Old Mar 3, 2009 | 12:31 PM
LVSBB6's Avatar
what brand is it?
Old Mar 3, 2009 | 01:17 PM
KGHtheII's Avatar
Originally Posted by LVSBB6
what brand is it?
Ultimate Racing
https://www.evolutionm.net/forums/ev...ce-skills.html
Old Mar 3, 2009 | 01:41 PM
Guru's Avatar
Mine is perfect and has been running for 6 months no problems. I had mine ceramic coated but that doesn't make a difference with a weld.
Old Mar 3, 2009 | 02:39 PM
JayDub514's Avatar
I've seen a T1R 02/DP housing split in two as well.
Old Mar 3, 2009 | 02:53 PM
shyong's Avatar
where did you see it?
Old Mar 3, 2009 | 03:17 PM
txfoster's Avatar
Have
UR DP
UR TP
Greddy TiC
We finally put in a flex joint from the system binding up!
Old Mar 3, 2009 | 03:22 PM
shyong's Avatar
UR o2 dp doesn't have a flex joint like the T1R unit?
Old Mar 3, 2009 | 03:28 PM
goofygrin's Avatar
The UR o2 housing/down pipe has a flex section.
I honestly believe it was a combination of high exhaust temps + coolish weather + potentially poor weld caused the issue.
In any case, UR is taking care of the issue.
Old Mar 3, 2009 | 04:30 PM
txfoster's Avatar
Mine must be an early one and did not have a flex joint and we had fitment issues anyway. Oh I don't have the one piece unit its 2 seperate parts.
Old Mar 3, 2009 | 06:47 PM
spdracerut's Avatar
IMO, if you go with a fabricated piece such as this, cracks are to be expected. Some can be more reliable than others depending on the grade and thickness of steel used, but in the end, I doubt any fabricated piece will be as robust as a cast piece. Heck, even cast pieces crack if not properly designed or of an inferior grade of metal. But they're more reliable than a fabricated piece.
Old Mar 3, 2009 | 09:59 PM
dD Spikey's Avatar
covered by warranty
Old Mar 3, 2009 | 10:20 PM
JayDub514's Avatar
Originally Posted by dD Spikey
covered by warranty
Thank goodness for that!
But yea, just like in all sorts of manufacturing there are defects here and there. The real way to measure the reputation is how they handle the situation. T1R replaced the split housing no questions asked, so I'm happy for the owner of that car.
Old Mar 3, 2009 | 10:24 PM
jeromski2003's Avatar
how about if you pay for installation is it covered too?
Old Mar 3, 2009 | 11:17 PM
LVSBB6's Avatar
^i doubt it.
