Paranoid episode inducing ticks.
Old Apr 4, 2009 | 07:41 PM
smoke4's Avatar
Just got done putting cobb ap and perrin catback on the car, and paranoid episodes kick in. I had the car running and got out and noticed a ticking from the engine bay. I have always noticed a certain tick (which sounded normal), this one was present with the original and sounds much faster, almost electric (if that makes any sense).
Anyways, what im looking for is a guru with these engines that can simply explain what types of ticking noises would be coming from the engine under normal conditions and any that could be from abnormal. I am assuming what im hearing is normal, and im just being a bone head.
The car also runs fantastic, and its not from the parts cooling and contracting. Its while the engine runs only.
Old Apr 4, 2009 | 07:44 PM
idriveanevo's Avatar
maybe an exhaust leak. double check anything you changed
Old Apr 5, 2009 | 06:50 PM
RogueValley's Avatar
If it gets louder as you approach the head of the engine, it's probably lifter tick. It's nothing to cry over, just a nuisance to hear.
Old Apr 5, 2009 | 06:56 PM
macPSU's Avatar
^+1
My engine ticks loud as hell and it's definitely annoying when the car is idling. It's normal though.
Old Apr 5, 2009 | 07:02 PM
chueu's Avatar
got it too...
Old Apr 5, 2009 | 07:14 PM
REDEVO08's Avatar
Originally Posted by chueu
got it too...
me 3
Old Apr 5, 2009 | 07:52 PM
aftershock141's Avatar
Mine ticks. I believe everyone's does.
Old Apr 5, 2009 | 08:01 PM
ak47m203's Avatar
this car is a ticker... mine too but what i will gonna do is drive another car and compare.
Old Apr 5, 2009 | 08:20 PM
xtremeboost's Avatar
Originally Posted by macPSU
^+1
Too load a "tick" and you maybe looking at another issue . We just found out recently we ran 11.9 on a blown motor with bent valves . We got lucky that the valve heads did not break off which would do for a really bad day . We have heard of at least 4 other cars not including ours with this same issue .
Just giving you a heads up .
Old Apr 6, 2009 | 10:46 AM
macPSU's Avatar
Thanks for the heads up. It's not audible when I'm inside the car, and it's barely audible when outside the car w/ the hood closed. Once the hood is up is when you notice it, and it just gets annoying.
I'd like to hear my car's idle compared to another X though, just to make sure what I'm hearing is normal.
Old Apr 6, 2009 | 12:47 PM
HybridKOOP's Avatar
How did you bend valves? Valve float at too high of an RPM caused piston to valve contact?
- Louis
Old Apr 6, 2009 | 12:58 PM
Well , not saying this may be the issue but you cannot hear the tick form inside the car , and very little even after you lift the hood .
Old Apr 6, 2009 | 01:00 PM
- Louis
Yes sir , we made contact with the pistons at high rpm's .
Old Apr 7, 2009 | 03:14 AM
smoke4's Avatar
I feel better that most other people hear it too. And if I go bending engine internals making less than 300 whp, im gonna look for another route.
Old Apr 7, 2009 | 04:59 AM
DarwinX's Avatar
Is the ticking coming from the fuel injectors? If so it's normal.
