What is the limit of the stock block?
Old Jun 28, 2009 | 10:56 PM
  #106
boostsaves's Avatar
Originally Posted by Fractur3
pretty sure ryan gate's car is stock motor from the valve cover to the oil pan. Hes running the prototype ams turbo kit, which i heard from some of the guys at ams that hes making around 550whp and he's raced it all last year and this year. Still running strong.
He is running an fp red? No
Old Jun 28, 2009 | 11:04 PM
  #107
GST Motorsports's Avatar
he was
Old Jun 29, 2009 | 11:31 AM
  #108
MIGHTYMOUSE1's Avatar
that sounds like a 35r
Old Jun 30, 2009 | 05:14 PM
  #109
just got some goodies from ferrea will post pics of the new drivetrain parts.
Old Jul 7, 2009 | 11:26 AM
  #110
BlackTrack's Avatar
Nope.
Old Jul 25, 2009 | 07:47 AM
  #111
thedragon's Avatar
if i wanted to run 30 psi on my red via meth would i need to change the piston and rods... or is meth just not a good idea since the motor is aluminum?
Old Jul 25, 2009 | 03:11 PM
  #112
Excalibur's Avatar
When would I need to change the pistons and rods on the gt3582r? I was planning on running low boost if it was an issue? 20psi or so. I can go less if need be.
Old Jul 25, 2009 | 03:22 PM
  #113
redleg225's Avatar
Like the post says just wanted to know what are the hp limits on the stock block has anyone blown them up yet how much boost do they handle before boom cause i see alot of people sleeving and block gards but no one has tested the limits on a non sleeved block who is to say they hold 800 hp who is to say they dont please big shops chime in
1. [Ninja Edited]
2. That is a gigantic run-on sentence.
3. The limit seems to be in the 650WHP range.
Old Jul 25, 2009 | 03:49 PM
  #114
TTP Engineering's Avatar
Originally Posted by olmoscd
1. [Ninja Edited]
Don't get twisted up in the 4b11 section Christian. I almost make that mistake everytime I see this thread in my email box.
Old Jul 25, 2009 | 03:52 PM
  #115
redleg225's Avatar
Hah! Hopefully you didn't see the ninja edited part.
Old Jul 26, 2009 | 10:46 AM
  #116
kozmic27's Avatar
Regardless of the original posters sentence structure, this is a very usefull question. The answer allows people to stop adding power at a level prior to imminent parts explosion, at least somewhat. If only the answers were simple.
I would honestly like to see some professional shops weigh in on this matter, with known data, on known properly tuned and modded cars. For one, improperly tuned and poorly modded cars can skew data. We have seen this in numerous threads already where people are tossing parts out the side of the block, with huge boost spikes, no tune, etc.
The other thing I have noticed is that the numbers move around a bit. I see in some posts where car "x" is claimed to be tracking with 550 hp on stock internals, and others where guys are shelling parts at much lower numbers. This leads me to believe that car "x" is perhaps properly modded, professionally tuned, with correct supporting mods, etc., where some others are ....not so much.
Old Aug 31, 2009 | 05:20 PM
  #117
tephra's Avatar
ok so i have read this thread rather quickly.
1) how come some high power evo's (gates311) are fine?
2) is it purely a function of boost, or overall power output?
3) is it linked to any particular age of build? ie earlier evoX's better/worse than later?
Old Aug 31, 2009 | 05:38 PM
  #118
tephra's Avatar
I'm going to answer one of my own questions here:
since this seems to be a problem of tolerances, it appears as though mitsu made the gaps to tight (both ring and piston/wall)
so rather than a function of boost, it appears to be a function of heat.
ie run meth/water or E85 and heat should go down significantly and thus expansion caused by heat should NOT be a problem...
Old Aug 31, 2009 | 06:01 PM
  #119
I just think that all you need to do is to make a weld in blockguard on number 4 cylinder that is the only place were it is not braced and maybe in between the cylinder so you dont have to spend 1500 to 2000 in sleeving a motor
Old Aug 31, 2009 | 06:02 PM
  #120
other than that i see the block making 800 to 875 whp
