ACT XTG6 or XTSS or maybe Exedy Twin
Hello
My car is runing with Evo 9 turbo and produce 370hp and 550Nm ( 405 lb/ft ) on crank ! the stock clucth is slipping need to replace it .
The exedy twin plates is very expensive i dont know sure need that.. to buy used one and rebuild it than total will be near the same as a new twin plate.
So I red a lot about the ACT and thinking beetwen the XTSS and XTG6 .
How streetable they r for DD ? I red lot of bad with the high rpm lockout :S I woud shift between 6500-7000rpm will this possible ? How long coud last these clutches I woud do 10-15 launch / month. If ATC than I will use the stock flywheel and machined it. Or no way go with exedy ??? Thanks from Europe !
