highflow cats
Old Oct 16, 2009 | 08:01 AM
seventhfactor's Avatar
Part of me has my heart set on the artisan exhaust with the mil spec welded in. I'll probably go with all ams though. I have to go to lunch with my girls from work and a testpipe would cause problems!
Old Oct 16, 2009 | 08:19 AM
DVDee's Avatar
I'm running the SX HFC, only had smell for the first week, then it went away. I'm sure any HFC will be fine man you will not notice the 1-3 hp difference. But CPE seems to have the smallest one around so it would seem it flows more.
Old Oct 19, 2009 | 01:23 AM
love67's Avatar
im looking for a HFC too....which one do you guys recomment?
Old Oct 19, 2009 | 03:51 AM
countdokoo's Avatar
running the invidia 100 cell HFC + 3" downpipe combo for over 3 mths now.
flows and sounds *almost* like a de-cat but without the smell.
Old Oct 19, 2009 | 11:28 AM
UT_Evo's Avatar
Any of the true 100 cell HFCs will flow nearly as good as the test pipe. Back in the day (before there were a lot of 100 cells available) I back to back dynod and made about 12 more whp with a testpipe over a non-100 cell HFC. The 100 cells supposedly flow tons better and will only be a difference of a few horsepower. Well worth it IMO.
Old Oct 19, 2009 | 12:11 PM
Brsox10288's Avatar
I dont see you getting much difference in the smell. I went from full stock exhaust to full tbe exhaust with test pipe. Maybe get a retune..
Old Oct 19, 2009 | 12:19 PM
derekste's Avatar
THIS.
There are plenty of high-quality, spun-core(key feature here) cats that will free up flow without the stigma of being an environment-hating-jerk or breaking federal emissions laws that you get with a catless test pipe.
I have Artisan's turboback (which, according to an earlier post in this thread, has a milspec cat) and couldn't be happier.
Old Oct 19, 2009 | 12:25 PM
delkat's Avatar
The dyno charts that were posted by GST a while ago on the 8-9 forum showed the Mil.Spec 100 cell to flow the closest to a TP but were still down 10-15hp compared to the TP.
Old Oct 20, 2009 | 06:21 AM
Just to be clear: the artisan single exit exhaust has a test pipe. I would have been custom welding in the mil.spec HFC. I've since decided to just start with an AMS HFC and go from there.
Old Oct 20, 2009 | 09:40 AM
DarwinX's Avatar
Good choice!
Old Oct 20, 2009 | 06:26 PM
Brsox10288's Avatar
ams cat will only fit ams exhaust i believe..
Old Oct 20, 2009 | 06:30 PM
UT_EvoX's Avatar
Nope, their cat pipe is a stock replacement, like every other one available.
http://www.amsperformance.com/cart/A...mance.com.html
• Bolts right in place of the factory catalytic converter
Old Oct 21, 2009 | 04:06 AM
DarwinX's Avatar
As stated above, this is not true.
My AMS HFC is currently connected to the stock DP and a Perrin CBE.
Old Oct 21, 2009 | 08:18 AM
Brsox10288's Avatar
this is the one i am referring too..
Old Oct 21, 2009 | 08:51 AM
Frankiago's Avatar
You do know you're in the Evo X forums and you're referring to an Evo 7/8/9 hfc/test pipe? Whether the 7/8/9 hfc is a universal fit or not has no relevance here?
I'll be getting an AMS hfc soon enough, just dreading the O2/DP install (O2/DP will go on with the HFC)
